Oil pressure maxed out!
Old Dec 6, 2006 | 04:10 PM
BlueDragon's Avatar
BlueDragon
Default Oil pressure maxed out!
Going to work my oil pressure maxed out today the gage went max and the DIC said 130lbs. Drove the car round trip and it seems ok (about 100 miles). Temps were normal no unusual sounds.
I know about the oil pressure sending unit going bad and plan on replacing it this week-end.
If I shut the car off and wait a while then start it the gage does its normal swing, and the DIC starts out at around 124 then climbs to
130. Is this indicative of the sending unit being bad?
What else can cause the oil pressure to max out.
Old Dec 6, 2006 | 04:13 PM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
It is the sensor, no other reason would the pressure go that high
Old Dec 6, 2006 | 05:25 PM
Casem1's Avatar
Casem1
Swapping the stocker for a positive displacement pump with a 6 inch stroke and a 2 inch swab.
Kidding! Bad sending unit.
Old Dec 6, 2006 | 07:05 PM
cruisemon's Avatar
cruisemon
Bad pressure sensor. Standard Part PS108 or 308 or some such is the better replacement part. Search this forum. It's a known problem, lots of posts on the topic. DO NOT replace with the OEM sensor.
Charlie
Old Dec 6, 2006 | 07:06 PM
LoneStarFRC's Avatar
LoneStarFRC
SEARCH!
Old Dec 6, 2006 | 09:51 PM
berryj's Avatar
berryj
Here's everything a growing boy needs for such a task as this:
http://forums.corvetteforum.com/show....php?t=1472249
Make it so, number one!
Seems to be an epidemic lately on the forum.
Old Dec 7, 2006 | 06:48 AM
Vetteoholic's Avatar
Vetteoholic
Best of luck buddy. I'm sure It's nothing too major. Maybe a sensor, but who knows.
Old Dec 7, 2006 | 10:09 AM
oldschoolvette's Avatar
oldschoolvette
I replaced mine last night. I used the GM part, this was based on a recomendation from a local vette shop who opened the doors in 1963. Good luck
Old Dec 7, 2006 | 04:05 PM
Oldvetter's Avatar
Oldvetter
If you show oil pressure with the ignition on and the engine off, your sensor is bad.
Old Dec 7, 2006 | 09:06 PM
Showdown's Avatar
Showdown
my sensor is maxed out also. good info guys.
To Oil pressure maxed out!
