What year did they do away with the proportioning spring in the C5 master cylinder? I am wanting to install an external proportioning valve, and need a master cylinder with no internal proportioning. Thanks.
So at least in year 2000, a car like yours does not have any biasing within the master cylinder, correct? And, as I understand what you are saying, neither do those with active suspension. All biasing is done external of the master cylinder both with standard suspension, as well as active suspension? Do you know if this is true of earier C5's?
I believe the external porportioning valve / biasing spring was away with in 2001.
Here's a snippet from Joe Oldham's article form the Z06 specs (and I believe all 2001 C5s)...
Pressure Modulator
The original Bosch 5.0 hydraulic pressure modulator is replaced by an improved Bosch 5.3 modulator. It is reduced in size, transmits less noise, and works better at low temperatures. It weighs 3.5 pounds less than the previous modulator and provides better apply response at lower temperatures (minus 20° Celsius), meaning that the system will become fully functional more quickly after a cold startup.
Dynamic Rear Proportioning
The enhanced system has dynamic rear brake proportioning capability, electronically balancing rear brake pressure to prevent rear brake bias, or lockup. This new software feature eliminates the need for a rear brake circuit-proportioning valve, resulting in fewer assembly parts and fewer brake pipe connections. In addition, the master cylinder pressure sensor is now integrated into the new Bosch pressure modulator.
