Nitrous Question
Old Sep 26, 2001 | 10:36 AM
rosecustom's Avatar
rosecustom
Default Nitrous Question
I'm considering adding the TNT wet-shot kit to my 2000 HT. Thanks to many postings I understand the on-board computer learns as it goes. The general consensis is it takes around 50 miles or so to adapt to mods such as induction or exhaust. If this is the case, how can the addition of nitrous be optimized since it is only used in short bursts? The only thing I can think of is the additional power surge is so devistating it doesn't need to be optimized. I appreciate all opinions... Thanks...
Jeff..
Old Sep 26, 2001 | 10:45 AM
levrac68's Avatar
levrac68
Default Re: Nitrous Question (rosecustom)
Good question. I also heard that you have to retard the timing to run the juice, which makes the engine run less than optimal when you're not spraying. Does anyone know if that is the case also?
Old Sep 26, 2001 | 11:31 AM
Big Carrot's Avatar
Big Carrot
You don't have to retard timing on a computer controlled vehicle. It does it for you. I don't know about you guys, but when I spray my car, it learns fast! No need to make any adjustments, just spray it and go!
Old Sep 26, 2001 | 05:55 PM
Eric94's Avatar
Eric94
Default Re: Nitrous Question (Big Carrot)
The only suggestion I can add is if you're using the HyperTech Power Programmer III, to NOT run it with the PowerTuning installed. The PowerTuning advances the timing somewhat, and this is something you don't want happening while you're running N2O. :seeya
Old Sep 26, 2001 | 06:24 PM
Tekno's Avatar
Tekno
In a wet kit, like you mention, the extra fuel needed is being added already. The only way to "optimize" a wet nitrous setup is to play with the fuel jets and get the desired air/fuel ratio. But this is not necessary since TNT has already done all this work for you, their kit like all the others is tuned for optimal performance. Each of their kits, unlike others as far as i know, is flow bench tested to make sure you get the performance you are paying for. The computer is being bypassed and extra fuel is being added manually.
Now in a dry setup like mine, where dry nitrous is sprayed before the MAF the computer senses the extra oxygen through the MAF and adds the extra fuel automatically through the injectors.
I like my setup because it is simple, but if I had not already owned the NOS dry kit I would have went with the TNT.
Good luck
Old Sep 26, 2001 | 06:32 PM
C5Cemo's Avatar
C5Cemo
Default Re: Nitrous Question (Eric94)
I agree with Big Carrot. The PCM will make all of the proper adjustments. Whether it's optimized for the spray or not is debatable but we KNOW it runs good. I'm more concerned about how it may effect NA performance after spraying a lot. At least the combustion chamber gets a good cleaning.
To add to Eric94's post, it is also recommended that users change to a colder set of plugs. Nitrous generates a lot of heat that can damage std. plugs or even over-gapped cold ones.
Old Sep 26, 2001 | 06:37 PM
66ImpalaLT1's Avatar
66ImpalaLT1
First of all, with a wet kit the computer doesnt need to adapt for any fuel changes. AFAIK you would need to tune it in with the fuel jets.
Second, the computer does not learn fuel changes at WOT anyway.
Eric
To Nitrous Question
