Cold Air Screens
Old Sep 26, 2001 | 11:33 AM
rosecustom's Avatar
rosecustom
Default Cold Air Screens
I understand these work well with The Twinflow, which I just installed over the weekend. I like the look of the screens but I'm worried about dirt and water getting under the hood and crapp'in up my engine compartment. Has anyone had experience with this. As always, I appreciate all the responses... Thanks
Jeff................
Old Sep 26, 2001 | 11:37 AM
COOL Z06's Avatar
COOL Z06
Default Re: Cold Air Screens (rosecustom)
That's one of the down sides.........but it doesn't really get wet, just dusty!
Old Sep 26, 2001 | 11:39 AM
Humy's Avatar
Humy
I originally put my cold air screens in for cosmetic purposes - to paint them red, but now with my Donaldson Blackwing - it was worth it. About dirt getting in - I have had them in for about 4 months now and haven't noticed anything bad as a result of the screens. Maybe in a sandy environment it could cause complications.
But I love my red cold air screens - would never go back.
:flag
[Modified by Humy, 3:40 PM 9/26/2001]
Old Sep 26, 2001 | 11:48 AM
Tiger Shark's Avatar
Tiger Shark
Hi, I have them too. I haven't experienced any noticeable increase in engine dust/dirt.
Old Sep 26, 2001 | 12:05 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
Now the real question: how hard are these buggers to put in? I've heard from some folks that they're next to impossible to install...
Additionally, do the fog lights still work with them installed?
Old Sep 26, 2001 | 12:11 PM
Humy's Avatar
Humy
Default Re: Cold Air Screens (Umrswimr)
Yeah they are a bi#ch to install. But once you see the housing from under, the car - it's self explanatory. Lots of bending your hands and arms in directions you never thought possible. Fog lights work fine.
:flag
[Modified by Humy, 4:16 PM 9/26/2001]
Old Sep 26, 2001 | 12:13 PM
Tiger Shark
I've heard hard unless you have a lift. I had mine done by the dealership's service department
Yes. Essentially, the West Coast Corvettes Cold Air Screens are factory housing which have been cut open. A criss-cross matrix (honey comb like) screen has been attached from the back side. The fog light holes are left intact. There is no obstruction on the light.
The Z06 screens completely cover the fog light area, so there must be some (probably small) diminishing/distorting affect on the fog lights if you use them.
[Modified by TargaC5, 10:13 AM 9/26/2001]
Old Sep 26, 2001 | 12:16 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
On my car we removed the front Facia and completely removed the housing that went around the fog lights. In its place we installed the Z06 screens and left the rest open. The OEM Fog Lights are mounted to the body of the car and have nothing to do with the Front Facia. We also installed PIAA 1100X lighting... What a Great Setup!! If you really want to do it right... this is the way to go.
vetterdstr
Old Sep 26, 2001 | 12:42 PM
Steve-O's Avatar
Steve-O
In reference to the install being tough, you must be talking about the full inserts that require removing a lot of parts.
I put my ZO6 screens in without a hitch in about half an hour. Just cut the black abs material with a new razor utility knife and velcro those babies in.
Old Sep 26, 2001 | 06:00 PM
CCS's Avatar
CCS
Default Re: Cold Air Screens (Steve-O)
I removed the front facia enough to where I could get in there with an angle drill and drill the location holes and install bolts... Its pretty easy ... put it up on some Rhino Ramps to access ...
Old Sep 26, 2001 | 06:25 PM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
I installed WCC cold air screens to compliment my twin flow intake. Seems to work fine. I live in a very sandy environment, and while I do get some dust in the compartment, I didn't really notice a huge before/after difference. Yes, putting them in can be a bitch. Go HERE for an install tip.
Good luck,
Dave
Old Sep 26, 2001 | 07:48 PM
Bartech's Avatar
Bartech
I agree with using the velco to attach the screens. Just use a 1" hole drill, punch 3 holes into the existing cover them velco the screens in. Works like a champ in 25% of the time of the full replacement :yesnod:
Old Sep 26, 2001 | 07:58 PM
vetterdstr's Avatar
vetterdstr
Default Re: Cold Air Screens (Bartech)
I used Velcro on my first set of Screens... (you can see where this is going) until one fell off on the road somewhere. :( now they are bolted in place and are not going to fall off the car. :yesnod:
vetterdstr :cheers:
[Modified by vetterdstr, 6:00 PM 9/26/2001]
Old Sep 26, 2001 | 10:50 PM
goldman's Avatar
goldman
Default Re: Cold Air Screens (vetterdstr)
They definately let more dust/dirt into the engine compartment, which indicates they are also letting air in...
They are very hard to install.. I drilled holes in my covers instead of replacing them... Forum user John Glen or JohnGlen or Gle(nn) has a template with an actual size layout of where to mark & drill holes in a very neat nice pattern... search for his username(s) & then check his website to see the template & get him to email it to you "actual" size.
To Cold Air Screens
