Today I recieved my Blue EE PCV Catch Can and installed it. It took all of about 45 minutes. It was a very simple process with the great instructions provided by EE. Here are the pics of the install:
You did your thread an absoloute justice w/the pics and the set up! Very clear and comprehensive and no one could possibly even come close to messing up an install.
My thumbs up to you! The best I've seen so far!!!
Thanks,Matt
Thanks. I 've only learned to do this form fellow forum members. I just pass it along in hopes that it might make it easier for the next guy. I learned a lot from similiar posts so I thought that I would just pass along the favor.
You will have nothing in your catch can.
I know because I just put mine in and checked it......The hose gets kinked where it bends from the PCV valve and it collapses. Then your dipstick will get "popped" out from the crankcase pressure.
They should have supplied an elbow or something or preformed hose that wont get sucked shut.
We have never experienced this problem. The 3/8" Fuel Line hose we ship is extra long so you should have plenty of slack in the line.
Its the direction of the PCV valve that sucks. It points away from the can so the line has to make a 180 (almost) to point to the can. I am just going to buy a plastic elbow. My hose was sucked shut. I checked the can for the first time and it was like BRAND NEW inside. Not even any residue. Thats when I started it up and noticed the hose.
Look at his pic in the first post. You can see the line bent and collapsing.
On my install the bottom of the can rests on one of the heater hoses coming out ofthe side of ther water pump and i cant unscrew the bottom half to check/empty unless I remove the bracket from the head and lift the whole thing up. It barely fit hitting that hose, so im gonna need to somehow change the bracket geometry to move it up about 3/4" an inch.
Maybe you could use a small preformed coolant hose, like the one that goes from the throttle body to the radiator, assuming the rubber is compatible with being exposed to oil/fuel in place of coolant.
From the pictures, it appears that another option would be to shorten the hose from the engine to the PCV valve. That should make the bend to the catch can less of and angle. Closer to a 90 deg. bend instead of a 120 to 180 deg.
Would it be better to move it up, or just make a spacer for between the bracket and the head to move the catch can forward?
A spacer and longer bolts might be easier than trying to make another bracket.
Spacer for the bracket wont work as it bottom of can would still hit the heater hoses no matter how far I spaced it out. Cant move it up any further as the bracket slots are already at their end of travel and if i go up further the top of can will also hit the cover. I can tug on the heater hose to force it out of the way while unscrewing the can, but it still hits and will not unscrew all the way.
I wont be checking it that often anyway, so I guess ill just deal with unscrewing the bracket and lifting whole can up to unscrew it when I do.
