2nd to 3rd gear grind, what does it mean?
Sep 26, 2001 | 01:19 PM
The shifting is great from 1-2 and 3-4, but from 2-3, unless I depress the clutch all the way and give it a bit of a pause, then there is a grinding noise. When I'm shifting as I do for 1-2 and 3-4 and so on, it engagues very smoothly, just with 2-3 it grinds. New clutch??? :rolleyes:
Sep 26, 2001 | 01:22 PM
Re: 2nd to 3rd gear grind, what does it mean? (Son93SL2)
SOunds like a synchro, and depending on how much grinding you've done, possible a 3rd gear.
I had a similar problem on the 1-2 and needed new scychros and a new 2nd. Covered under warranty.
I'd bring her in as soon as possible, because if a sychro self destructed, there could be pieces in there causing more damage.
Jonathan
[Modified by yellow01, 1:26 PM 9/26/2001]
Sep 26, 2001 | 01:34 PM
Re: 2nd to 3rd gear grind, what does it mean? (yellow01)
Jonathan
[Modified by yellow01, 11:22 AM 9/26/2001]
Oh, sounds bad. :(
So what does it mean that if I granny shift and it shifts fine...?
Sep 26, 2001 | 02:25 PM
I just spoke to the dealer... said that it was probably a syncro... quote starting at $1100 :( Better tell my brother to granny shift for a while.
Sep 26, 2001 | 02:27 PM
I thought you were talking about your Saturn. :rolleyes: :rolleyes: :D
Sep 26, 2001 | 02:29 PM
Re: 2nd to 3rd gear grind, what does it mean? (JWSchmidt3)
I just figured you guys would know best. :D
It's his 300ZX
Sep 26, 2001 | 02:36 PM
Synchro dude! I have had to replace mine.
Sep 26, 2001 | 03:28 PM
Re: 2nd to 3rd gear grind, what does it mean? (Shinobi's97)
$1100!!! ouch. How old is your vette? I would push for warranty. Its worth a try.
Jon
2nd ,
3rd ,
automatic ,
car ,
change ,
corvette ,
gear ,
gears ,
grind ,
grinding ,
grinds ,
mean ,
synchro ,
whats
