Squeaking like an old bed
Old Dec 12, 2006 | 07:20 PM
stormrider's Avatar
stormrider
Default Squeaking like an old bed
For about two weeks now my 02 coupe with 58K miles has been squeaking like an old bed every time I go over a bump or accelerate quickly. The only mods I have done are Z06 sways (and yes I put tons of Electric lube on all the bushings), new rotors, calibers, pads and had Corsa’s installed by a muffler shop. Anyone have any clues to what might be causing the squeaking?
Old Dec 12, 2006 | 07:46 PM
FRCTony's Avatar
FRCTony
It's the sway bars.
Old Dec 12, 2006 | 07:54 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by FRCTony
It's the sway bars.
I did the whole T1 setup recently and they squeeked at first. The fix that I found was to stack a washer (or two) on the two bolts, between the back of the bushing and the rear aluminum suspension cradle. It moves the bushing out just enough to stop the squeeking.
Old Dec 13, 2006 | 04:17 AM
MeekRN's Avatar
MeekRN
i had same squeeking noise in the cold, i live in arizona so it took a while for me to notice the noise. it is the sway bars, you can do 2 things, i sprayed white lithium grease all over all the parts of the anti roll system front and back, it stopped most of the noise, but 1 year later its bac,, this time i took it all apart and sprayed white lithium grease between the roll bar and the rubber bushings, also cut a thin V notch running sideways across the bushing. now if it starts to squeek again, i have access to the inside of the bushings. now with that squeeking gone, i notice my steering wheel squeeks now, but only when i turn it. i will hit that next.
To Squeaking like an old bed
