Oil Filter removal
Old Dec 13, 2006 | 12:53 PM
RaleighSS's Avatar
RaleighSS
Default Oil Filter removal
Ok....
Just did an Oil Change on the ole Z06 and from reading other threads found that the Fram sucks and want to take it off..... by just pulling the filter how much Oil will i loose? Will I loose just whats in the filter?
Old Dec 13, 2006 | 01:17 PM
Architect's Avatar
Architect
that filter is perfectly fine. save the time and hassle.
don't believe everything you hear... or in this situation, read.
Old Dec 13, 2006 | 02:17 PM
exile's Avatar
exile
The man deserves an answer to his question TTT
Old Dec 13, 2006 | 02:22 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Originally Posted by RaleighSS
Ok....
About a quarter of a quart maybe a little more if you are using the stock 6.5 quart change. I pre-fill my filters before installing them. I use 7 quarts when I change oil on my 02Z. I find it puts the oil at the top of the full mark. Put the new filter on and run the car. Checking for leaks. Let sit for an hour or so, and check the stick. You should not have to add much to bring it to the full level. (You will not hurt anything with extra oil) Z's can hold up to 8 without problems) Good move on the filter switch. Even the stock one is better rated then the Fram series. Don
Old Dec 13, 2006 | 02:51 PM
thisMSGgood4me's Avatar
thisMSGgood4me
When I change just the filter, I have found that I use about a half quart, filling the new filter with oil and using the rest of the half quart to bring the oil level back to the full line on the dipstick.
Old Dec 13, 2006 | 08:25 PM
RaleighSS's Avatar
RaleighSS
I am sure this filter is just fine..... some say loss of a few PSI.... I went the sale route at autozone and got the fram... usually run the K&N... so just a peace of mind for me... No issues i am sure....
To Oil Filter removal
