LS1 powered car goes 9's ... N/A!!!
Tom
Tom
BTW, SW's 60' was not 1.4 to the best of my knowledge, it was 1.5x. That is a pretty big move!
Again, Congrats to SAM and Judson. You have definitly raised the bar! Kinda makes me want to go back to school. :conehead
Tom
And if I am not mistaken, there has allready been a GM owned yellow LS1 camaro that has allready been in the 9's NA, a long time ago. Granted, it was set up as a drag car, but it was in fact LS1 powered.
[Modified by kewlbrz, 9:36 PM 9/27/2001]
Tom
kewlbrez has provided alot of good information to this forum. Everyone is entitled to their opinions.
[Modified by TargaC5, 9:58 PM 9/27/2001]
The SAM car went 9.97 on MOTOR!!! :eek:
Get it guys .... MOTOR!!! Do you have any idea what this thing would do on a 135 shot??? Bottom 9's and a huge MPH!!! You can not compare this car and SW's car for many reasons.
This was simply a congratulations to Jud and the SAM crew for an incredible accomplishment. In no way was it to say that the F-body is a better car, I OWN A C5 FOR GOD'S SAKE!!!!! :mad
I still stand by my statement that gas to gas this car would crush SW. Total bench racing but hey facts are facts. The SAM SS runs door to door with SW on a 200 shot, no reason to believe it wouldn't crush the C5 if the SS were on a 200 shot. Even if they just sprayed it in 3rd gear, it would walk off and leave the C5.
SW says his car was on a 135 shot when he went 9.98 and if he says so that's good enough for me.
_______
Torch Red C-5 with some mods!
I agree, the SAM's car is fast. And in a drag race it would(should) beat my C5. But like I said before, two different cars. Put a IRS rear end and a stock 6sp in it and see how fast it is. As you aware, a good launch is everything in the quarter. Also, on the 135 shot I did run 145.3 mph. I would love to run it from a roll motor on motor from 50 to.......and we'll see who crushes who.
SW
SW
No offense, but I still think the SAM camaro would get you from a roll motor to motor.
You are trying t keep the comparison on level palying fields saying that the Camaro has a solid axle, set up for drag racing, etc. but the fact is the playing fields are not level for the the reason that you are using a power adder (nitrous).
I completely agree with SW and most others on this...these cars are not to be compared. There is no point to it. This post was nothing more than a tribute to the baddest LS1 motor in existence at this time, nothing more.
Back to the topic.
Congrats Judson and crew. The bar has been raised!
I did say I would run motor to motor from a roll. That would be interesting. :D
SW
I understand Al Cordova and the GM owned yellow LS1 camaro went 9's naturally aspirated a long time ago.
We are all gear heads here, and emotions fly at times, especially in these times. :flag
[Modified by kewlbrz, 3:04 PM 9/28/2001]
Is SAM's a solid roller? SW's? What's the main difference?
Solid lift cam, 260 @ .050, .700 lift, 113 LSA, Jesel 1.7 ratio adjustable rockers
Ported LS6 heads, 345 cfm intake flow @ .600 lift, exhaust 250cfm(?)
Stock LS6 intake manifold
Grotyohann headers
Ed Wright tuning, 8000 rpm redline, 31 degrees total timing
Jerico Road Race 4 Speed Tranny, McCloed Clutch, Ford 9, 4.30 gears
M/T ET Drags 11.5 x 28"
As far as weight I read SAMs car race weight was 3370 lbs, so it’s gotta be about same as SW, I suppose. Of course to get an F-body to that weight you’d have to gut the crap out of it (especially considering it’s got rollcage, 9”, etc..)
So, basically, judging by the trap speeds SAMs car makes just a bit more power on motor (mostly due to higher CR I suppose, maybe bigger cam [8000rpm redline and all]).
Obviously it’s setup for drag (4.30 gears, 9”, 28” slicks, most likely drag suspension), so ET differences are much more pronounced…
Your mph is awesome and I agree that motor to motor from a roll it would be a good run. The SAM car would be gear limited and your top speed would be hard to beat.
My example was the SAM car on gas against your very impressive C5 ias it sits in a 1/4 mile race would/should go easily to the Camaro.
Please understand that I'm not trying to take anything away from your successes with your C5. I totally respect and admire what you have done with that car. It's really quite amazing. Running the stock tranny and IRS is without a doubt a huge disadvantage.
""It may be a small block chevy, but at this point, its a far cry from an LS1.""
It is a sleeved LS1 stock block with stock ported LS6 heads and a stock LS6 manifold with a stock throttle body and another stock GM MAF with commercially available headers. It's no different from anything that ARE or MTI does except it's just faster. We even use the stock GM head bolts!
The car is raced in NMCA competition so of course it's setup for drag racing. The stock chevy drivetrain stuff doesn't hold up to nine second manual transmission passes very well so it's got a road race Jerico trans with a real clutch and it works and doesn't blow up anymore. We have to make rounds in competition continuously not one run wonders so the driveline is overbuilt. The trans is not that expensive and is in fact cheaper than a built auto and converter. You can upshift and downshift just like any other trans with the Jerico. That night the computer was acting up a bit and Jud said the car was pulling all the way through the lights so I am sure we'll see more like almost 140 later in cooler weather.
SW's vette is a completely different animal being still a true street car and having IRS. I don't think anyone expects it to run the same from a standing start drag race since the car isn't setup for that and our car is. I used to autocross at SPOKES events in Austin a lot and I know EVERYONE loved to watch SW pimp his baaad aasss C4 vette at Heritage center and other places. Seeing a 600+ hp vette go around an entire course sideways with the tires smoking is something everyone should see at least once! I think SW used to get like top time of the day at almost every event in that car back then even including lots of real race cars! I know people who's whole lives changed just by watching SW make a few of those runs. They would never be the same after that.
http://www.samracing.com/99camaro.htm
[Modified by RACER7088, 3:11 AM 10/2/2001]
