Is WD 40 Ok?
Old Dec 13, 2006 | 10:23 PM
C17driver's Avatar
C17driver
Default Is WD 40 Ok?
I used wd 40 on my paint to get some bugs off the other day, was that ok. I was told it was, but what do you guys think?
Old Dec 13, 2006 | 10:36 PM
Rob Petyo's Avatar
Rob Petyo
I've used it before with no problems. Just use a mild soap and water solution to wash it off when your done.
Rob
Old Dec 13, 2006 | 10:45 PM
chuckster's Avatar
chuckster
I use it ALL the time on paint.. Never had a problem..
Old Dec 13, 2006 | 11:04 PM
kevin40zx's Avatar
kevin40zx
Rob
Old Dec 13, 2006 | 11:34 PM
BLWN1's Avatar
BLWN1
I seen it advertised by them for that purpose in Hot Rod a few years back, thats when I used it.....
Old Dec 14, 2006 | 02:15 AM
PierEagle's Avatar
PierEagle
Oh, Oh, you're in trouble. Your paint will start peeling off in 40 days. That's how it got it's name, Will Destroy in 40 days.
Just kidding. It's good stuff. I've used it for years as a road tar remover with no problems.
Cheers
Old Dec 14, 2006 | 08:59 AM
David426's Avatar
David426
Its made of fish oils
Old Dec 14, 2006 | 09:14 AM
briann510's Avatar
briann510
Is there something wrong with using soap and water to get the bugs off? Ive never had bugs that wouldnt come off easily with warm water and soap.
Old Dec 14, 2006 | 10:29 AM
jfrc's Avatar
jfrc
its fine
use to clean before you wash the car
Old Dec 14, 2006 | 11:19 AM
ALLEGRO's Avatar
ALLEGRO
Originally Posted by jfrc
its fine
It will remove some really stubborn stuff. A really good secret before you wash.
Old Dec 14, 2006 | 02:14 PM
jrose7004's Avatar
jrose7004
That's what I do!
Old Dec 14, 2006 | 02:36 PM
oldschoolvette's Avatar
oldschoolvette
works for rubber as well
Old Dec 14, 2006 | 02:46 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I still have the rubber on my car Al!
It does work, I have used it with little issues on my paint.
Micah
Old Dec 14, 2006 | 04:17 PM
It will be OK, but I would be sure and wash the area after using the spray.
Old Dec 14, 2006 | 04:49 PM
Vet Interested's Avatar
Vet Interested
Clean it and if you are still worried, throw a coat of wax on it. Good as new.
Old Dec 14, 2006 | 05:59 PM
RAMMAN's Avatar
RAMMAN
Pro Mechanic
St. Jude Donor '16 thru '26
I have used it for years to remove tar. Never caused any problems with the paint.
Old Dec 14, 2006 | 06:05 PM
DPG's Avatar
DPG
St. Jude Donor '06
with good paint protection it should come off with just warm water and car soap.
To Is WD 40 Ok?
hotwheels57's Avatar
hotwheels57
...it's good on toast...
Old Dec 14, 2006 | 08:38 PM
Larry Salsman's Avatar
Larry Salsman
Try this it is a lot cheaper and will not hurt anything. I have used it for years. Arm and Hammer baking soda. It cost 28 cents for a box. Just wet a sponge and pour it on. Wet the car and rub it on. Then just wash it off with water.
Old Dec 14, 2006 | 09:33 PM
Tigershark3's Avatar
Tigershark3
I've used kerosene for years to get tar/bugs off with no problems. Cheaper than WD but use disposable latex gloves as too much on your skin is not good. .02 deposited.
