Larger than 60lb injectors. Options?
Old Dec 14, 2006 | 01:57 PM
MPRTKLR's Avatar
MPRTKLR
Default Larger than 60lb injectors. Options?
What is available that is larger than the 60lb injectors by Motron but are not going to cause serious problems are need extras? I was told RC made 73lb injectors, but I have not been able to find them anywhere. I am thinking of going with a dual pump setup and maybe 73lb injectors and need help. I guess now, my goal is ~700 whp. Thanks in advance.
MPRTKLR's Avatar
MPRTKLR
forgot to mention, this is via turbo, which from my understanding is more demanding on the fuel system.
Old Dec 19, 2006 | 09:04 AM
Old geezer's Avatar
Old geezer
Default ????
The 60PPH rating on the Mototrons is calculated at a Fp of 43psi, 3 bar...
Have you calculated their flow rate, using the FP of your system???
My calcs show you need a 65PPH inj at 3 bar, at an estimated 775 FWHP, at 90% DC, .6 BSFC.
Running the Motos at 60PSI, base FP = 70.9PPH flow.
This should cover your FWHP, IF the FP reg is boost referenced. [BTW, the calcs on inj size are made using FWHP, not rwhp..]
HTH,
Old Dec 19, 2006 | 11:10 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
shoot Slowhawk a pm, he's setup a good amount of LS1 cars north of the 600rwhp mark
Old Dec 20, 2006 | 09:32 AM
Just Enough's Avatar
Just Enough
Try this link. This guy really knows large injectors.
http://www.acceleronics.com/dealers.htm
To Larger than 60lb injectors. Options?
