Are these heads worth it???
Old Dec 15, 2006 | 02:02 AM
Genesis_26317's Avatar
Genesis_26317
7th Gear
Default Are these heads worth it???
Okay guys this is my first post here and I guess I should make it a good one.
http://www.gmpartsdirect.com/results...umber=12480090
Is this worth putting on my 2002 Z06???
Also can all the valves, springs, etc, etc, just be swapped from my stock heads and then stuck on the C5-R heads?
Is it a direct stick on a LS6 block? Do I need a new intake manifold?
Are the square ports better than the D-shaped ones?
I would like to have real C5R type parts on the car to help it seem more "true" to its name but if it is a b$tch to get on the car then I'm paying $1750.00 for heads that require porting before they can even be put on.
Old Dec 15, 2006 | 02:21 AM
Bubbletop409's Avatar
Bubbletop409
Don't think they will work on a stock Z-06 short block. Did you read the features? Large bore, valve size, intake port shape, etc. Those are race castings in the rough form, would give poor throttle response for street use even if you could bolt them on.
Old Dec 15, 2006 | 03:19 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
no not for your motor plenty of other heads available at good prices. Do a cam first if not with the heads,
Old Dec 15, 2006 | 07:23 AM
Vetteoholic's Avatar
Vetteoholic
AFR Heads & Cam =
To Are these heads worth it???
