Difficult spark plug solution $6.99
Old Dec 17, 2006 | 03:24 PM
Vettman 1's Avatar
Vettman 1
Default Difficult spark plug solution $6.99
Here's a $6.99 solution to the difficult spark plug removal (behind vacuum booster) Thank you Pep Boy's
Old Dec 17, 2006 | 03:56 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Make sure you get the one with the rubber insulator inside. It helps holding the plug for cylinder #7
Old Dec 17, 2006 | 04:44 PM
Tigershark3's Avatar
Tigershark3
I didn't have that particular tool but yup universal + a couple of extentions+ socket is the key on that plug.
Old Dec 17, 2006 | 05:07 PM
Vettman 1's Avatar
Vettman 1
It has the rubber inside the socket
Old Dec 17, 2006 | 05:38 PM
RonVette2's Avatar
RonVette2
Very nice, and a good price, the one that does the same job from one of those tool trucks is about $30+, obviously because of the "Name" on it. Ask me how I know...
Old Dec 17, 2006 | 06:12 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I like the SnapOn swivel head ratchet; a must have for many jobs
Old Dec 17, 2006 | 07:14 PM
craig04c5's Avatar
craig04c5
I just took all my plugs out and put anti-seize on the threads and dielectric grease on the boots. The problem isn't so much getting to the plug under the brake booster but getting the $%#@&* boot off. You can't get you hand in there enough to twist and pull it. Be careful when using a swivel socket that you don't break the insulator when putting it back in.
Old Dec 17, 2006 | 07:24 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
I don't have a problem getting the plugs in or out now with the headers on.
Old Dec 17, 2006 | 11:10 PM
VetteTech81's Avatar
VetteTech81
I agree... that and the swivel spark plug socket like above.. makes it easier..
-=Rick
To Difficult spark plug solution $6.99
