Passenger Door Lock - Tried to Fix...
http://forums.corvetteforum.com/show...1218327&page=4
Question: Now my PASSENGER door (the one that had trouble unlocking) will not lock or unlock and the window doesn't work. I still have the PASSENGER door panel disconnected so maybe that is the problem? I only messed with the door unlock relay (the middle relay of the three) so I don't understand why none of the features seem to work when pushing the buttons on the DRIVER's door that lock/unlock/window operation of the PASSENGER door.
One other thing, I got a code on my DIC:
B2285 Battery #2 Fault DCM-RIGHT
Any thoughts? Should I just order a new Door Control Module?
PS - This is typical for me trying to do work on my car. Usually ends up being more than I anticipated.
I tried messing with them tonight and nothing happened. I can't even get the plugs out of the DCM. Maybe I'm missing something about removing them. I know on the clear and red harness there is a little tab to depress. On the black and gray harness there is a piece of plastic that needs to be removed first. I did these things but still can't get the wire plugs removed from the DCM!!
Thanks!!
Very happy now. Just need to put the door panel back on and she should be ready to roll!!
i bought a replacement on the forum and it has been perfect since.
