run flats
Old Dec 23, 2006 | 08:38 PM
80vetla's Avatar
80vetla
Default run flats
just got a 99 vert and had a question. Actually knew nothing bout run flat tires till i got this car. I just know the road noise is unbeliabily loud with top up. Anyway does run flats mean when you get a flat you can limp to the nearest station or does it mean you dont have to worry about getting flats? Also when you get a flat does it show up on the dash readings? Also drove the car one day then stored it and havent really looked close since its not at my house but what im reading here is that there is no spare? sorry for stupid questions!
Old Dec 23, 2006 | 08:43 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Run flats mean you can drive on them (usually at 55 mph for 50-200 miles, depending on the manufacturer). C5's have a tire pressur monitoring system that will alert you if a tire is losing pressure - and which one as well.
Old Dec 23, 2006 | 08:48 PM
80vetla's Avatar
80vetla
Thanks chuck! so their is no spare? The guy before me changed the wagon wheels for 2000 thin spokes so the system isnt hooked up ,is that hard to hook back up?
Old Dec 23, 2006 | 08:58 PM
LoneStarFRC's Avatar
LoneStarFRC
You are correct. No spare.
Don't know why the system wouldn't be "hooked up". All he had to do was move the sensors over to the new rims. One way to tell if it's working normally would be to drive and select tire pressure readings on the DIC. You've stored the car though and the sensors "sleep" to save battery life while not moving. If you select tire pressure readings now, they won't have any indication of pressure, which is normal. The only time they will notify you automatically is if there is one or more tires that are too low or too high in pressure, and here again the car has to be moving to "wake up" the sensors.
Old Dec 23, 2006 | 09:06 PM
80vetla's Avatar
80vetla
Thanks for reply! My understanding is that he bought tires and rims and put them on ,probably himself. Every time i started the car the monitor would read out some thing like "check tire monitor system" or something to that affect. I just hit the reset button everytime i restarted the car. It would not appear again till i restarted.
Old Dec 23, 2006 | 09:09 PM
LoneStarFRC
Welp, from that I can only assume he did not transfer the sensors over. It's very easy to do. Maybe he had a couple of them getting hinky and he didn't want to pony up for new ones.
Old Dec 23, 2006 | 09:17 PM
chuck1026's Avatar
chuck1026
You can try calibrating them. Just follow the instructions... https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Dec 23, 2006 | 09:24 PM
80vetla's Avatar
80vetla
Thanks guys!
Old Dec 27, 2006 | 10:55 AM
jovette's Avatar
jovette
Suggest you pull out the owner's manual and read............many current and future questions will be answered by following this simple instruction.
Old Dec 27, 2006 | 01:22 PM
emquad46's Avatar
emquad46
The Goodyear (EMT) extended mobility tires (run flats) can be driven at 55mph for 200 miles(max) with no air pressure. I wouldn't drive that far without air pressure but it's conforting to know they can't blow out. If your DIC says a tire has no pressure get it serviced immediately. The tires are very noisy. I have 36K on mine (lots "O" tread left) and can't bear the noise anymore. I getting Michelin run flats in the Spring!!!!
Old Dec 27, 2006 | 02:00 PM
GUSTO14's Avatar
GUSTO14
As a side note, back in the day when Goodyear and Chevrolet started going down the run-flat road, some may recall they did a bit of a stunt to convince the public of just how capable run-flats were...
They took a Corvette and let the air out of one of the front tires and did "a lap of America" with it. I believe it was somewhere around 6,000 miles and drove it at highway speeds. I'm sure no one from Goodyear or Chevrolet would ever suggest you or I try it, but they did. It was reported in a number of national automotive magazines at the time.
Am I the only one that remembers this?
GUSTO
Old Dec 27, 2006 | 06:05 PM
hueyhue's Avatar
hueyhue
Who els makes them?
Old Dec 27, 2006 | 06:26 PM
LoneStarFRC
Originally Posted by hueyhue
Who els makes them?
Firestone, Pirelli, etc. Check on Tire Rack's site. Seems like remember seeing BFG, Kumho also. I think there may be a RF version of the GS-D3 too.
To run flats
