Squeeeeeeeeeeekkkkkkk!!!!!!!
Old Dec 25, 2006 | 11:13 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Default Squeeeeeeeeeeekkkkkkk!!!!!!!
Kind of bummed, took my worn polymatrix pads off Saturday, while installing speed bleeders, and installed hawk hps plus. Bedded the pads Saturday night, all good. Yesterday 30-50 miles on the new pads the squeek is embarressing enough that I'm going to change them out. anyone else have a major squeek with these pads?
Old Dec 25, 2006 | 11:36 AM
atljar's Avatar
atljar
While braking, or when barely on the brakes either appling or releasing?
If its while barely touching the brakes, put some antisqueak on the BACK of the pads (not the friction surface). I like the permatex stuff that is in an aerosol can. It sprays a nice coat of this blue glue stuff
Old Dec 25, 2006 | 12:16 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Low speed approaching traffic lights, while applying. At race speeds, no noise at all. I've never even heard of antisqueek, thanks.
Old Dec 26, 2006 | 03:37 PM
GeorgeZNJ's Avatar
GeorgeZNJ
The only stuff I found is made my by gunk, cll;ed squeal medic. It says to spray directly on rotor surface, doesn't sound like the suff you're referring to.
Old Dec 26, 2006 | 05:16 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
yes, Hawk HP Plus make a bunch of noise
I switched to the HPS, S for street
the HP Plus are a great pad, but make a ton of noise and dust
Old Dec 26, 2006 | 05:57 PM
C5_Baker's Avatar
C5_Baker
I totaly agree with Steve. I put a set of the Hawks on mine and swithced back due to the noise and dust.
Old Dec 26, 2006 | 10:12 PM
GeorgeZNJ's Avatar
GeorgeZNJ
I'll take that as my que to switch back.
Old Dec 26, 2006 | 10:15 PM
Dirty Howie's Avatar
Dirty Howie
If they are the Hawk HP Plus they will squeak ALL the time.......EXCEPT at the track and for a short while there after.
Shoot me a PM if you want to get rid of them.......
DH
Old Dec 26, 2006 | 10:40 PM
atljar's Avatar
atljar
No not the same. Before you ditch the pads give this stuff a try and see if it works. It will eliminate any noise cause from the pads moving around/vibrating. If the friction material itself is causing the sound, it wont do anything for you.
You can buy it at any parts store for under $5. Liberally spray on the back of the pads and wait for it to get semi tacky, then reinstall the pads.
Here is an ebay ad so you can see what it looks like....
http://cgi.ebay.com/ebaymotors/PERMA...QQcmdZViewItem
Old Dec 26, 2006 | 10:43 PM
GeorgeZNJ's Avatar
GeorgeZNJ
DH
I just took the polymatrix pads off, i'll see if i can find this other stuff to use, if not I'll pm you.
GeorgeZNJ's Avatar
GeorgeZNJ
I'll try again, different autoparts stores tomorrow, thanks.
Old Dec 27, 2006 | 03:23 PM
Dirty Howie
Just don't ruin them by spraying something weird on them .....
If you check in the Track section you will see that they are know to be very noisy.....its the pad material itself.
I used to run the HPS but switched to HP Plus cause of better track performance. Now I just play the stereo louder and forget about it on the street.
DH
To Squeeeeeeeeeeekkkkkkk!!!!!!!
