Anyone using a line lock (roll control) on a C5?
Old Sep 28, 2001 | 07:05 PM
EvilZ06's Avatar
EvilZ06
Default Anyone using a line lock (roll control) on a C5?
I'm interested in getting a linelock for my Z06, but I don't know which one to get. If you have one, please post which make and model you are using, where you bought it from, rough cost, and what's involved in the install.
TIA. :cheers:
Old Sep 28, 2001 | 07:16 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Anyone using a line lock (roll control) on a C5? (EvilZ06)
Not for a c5 (my f-body) but I've used the Hurst Roll control and made my own brake lines to route to the ABS module. I ditched the wiring that came with it and used my own relay, status LED, wires, and switch.
bruce1's Avatar
bruce1
I got one.
It is a TCI brand, from Summit Racing.
Old Sep 28, 2001 | 07:23 PM
bruce1's Avatar
bruce1
here is a link
http://store.summitracing.com/defaul...rchType%3DBoth
Old Sep 28, 2001 | 10:30 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I have the TCI also. It was installed by the Vette Doctors in NY. It took about an hour and a half to install. The unit cost about $100 and the switch (hurtzs switch) cost about $30.
If you are looking to install yourself, you need a special double flaring tool for the brake lines. Finding the fittings you need is not too easy either.
Old Sep 28, 2001 | 11:00 PM
EvilZ06's Avatar
EvilZ06
Default Re: Anyone using a line lock (REDGAR)
Thanks for all the help guys. :D
How difficult is the install? Is it something that could/should be attempted by a novice. Any pics?
Is there anyone in the SF Bay Area that has one?
Thanks. :cool:
Old Sep 29, 2001 | 04:53 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Easy, one of he few mods I did myself except bleed the brakes!
Old Sep 29, 2001 | 08:15 AM
CoolSSBoy's Avatar
CoolSSBoy
Default Re: Anyone using a line lock (wallstAL)
Does the line loc go into the line out of the front or the rear of the master cylinder? I know the F-bods go into the rear and was just wondering. Thanks
AJ
Old Sep 29, 2001 | 10:49 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Default Re: Anyone using a line lock (CoolSSBoy)
I forget which one but it is marked on the master cylinder with a F for front and R for rear. You lock the front
Old Sep 29, 2001 | 07:55 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Anyone using a line lock (Godspeed)
WOW, all your missing in that signature are photos of your kids :D :D :D
Old Sep 29, 2001 | 08:15 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
TCI ROLL STOP
Activation Button
Activation Button
Solenoid
Another View
Located between the Active Handling Unit MC1 Porporting Vale on the 2000 C5.
Old Sep 29, 2001 | 11:40 PM
ROD BROWN's Avatar
ROD BROWN
what is a line lock? what does it do? :chevy :confused: :confused:
Old Oct 1, 2001 | 12:56 PM
EvilZ06's Avatar
EvilZ06
Al, thanks for the cool pix. :cheers:
Rod, I sent you email.
A line lock is a device used to stop either the front or rear wheels turning whilst leaving the other set (the drive wheels) free to move.
It is used by drag racers for burnouts and stop hold the car on the line after staging.
Hope this helps. :D
To Anyone using a line lock (roll control) on a C5?
