97 going back together......
Old Dec 26, 2006 | 11:47 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default 97 going back together......
TT reassembled with ECS u-joints inside..........can't tell it
And the rear with new seals & lube
And the Rossler with a few extras.......
After talking with Carl........I had him move the fill/check plug away from the exhaust flange area for easy access
I have a few more details to finish, then I hope to slide it all back in later this week
Old Dec 26, 2006 | 03:10 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
What does Julie think about the use of kitchen towels in the shop?
Looks good otherwise
Old Dec 29, 2006 | 12:19 PM
Cruise-In V Veteran
NCM Ambassador
All my towels Bro
The Fuddle TC;
Got the TT back in w/o issues........dropped down and ready to mate the trans/TC/rear up...that was to easy
And just to make sure I got the upper wiring harness back in.....a little finese with a stick
Now the problem, went to reinstall the rear to craddle mount..... 1 bolt tightened.....the other spun Never good to have the threads come out on the bolt!
Time to go back to playing........will install a longer bolt with a nut, plenty of room
Old Dec 29, 2006 | 12:28 PM
SteveDoten's Avatar
SteveDoten
any plans on using the 6 bolt T/C plate?
Old Dec 29, 2006 | 01:17 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Can't never beat a good stick... don't know what you might need it for... best tool in the shop
Looking good... that trans looks serious!
Old Dec 29, 2006 | 06:14 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Awesome setup you have going back in
Old Dec 29, 2006 | 06:54 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Vette pr0n
Old Dec 29, 2006 | 07:53 PM
JoeyG's Avatar
JoeyG
Steve you weren't thinking about cold beer and Quick 1/4 mile times while wrenching, were you?
Old Dec 29, 2006 | 11:18 PM
Brad@RevXtremeAutoSports's Avatar
Looking good Steve
Old Dec 30, 2006 | 12:32 AM
Cruise-In V Veteran
NCM Ambassador
No plan on the 6 bolt.....haven't seen the need for it.
The trans jack made to alignment for 1 person awsome, TC bolted right up. If you have an ABS block in the back, for an A4 this works great!
All I have to do is fill the trans/rear, bolt up the cradle, finish bolting a few things and I will crank it up
Old Dec 30, 2006 | 05:58 AM
Nice progress being made.
Old Dec 30, 2006 | 09:46 PM
Cruise-In V Veteran
NCM Ambassador
Closer................just a few more small things and I will start it with no exhaust to check if all is ok, get the tranny fluid right, and warm it up so I can tighten the front shaft coupler.
The deep pan is tucked up nice and tight........
Old Dec 30, 2006 | 11:28 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Very nice progress
Old Jan 2, 2007 | 07:58 AM
Cruise-In V Veteran
NCM Ambassador
Got it started early on NY's eve, put more tranny fluid in........with open headers, all seemed ok.
Finished the tunnel plate(sprayed the exhaust side with high heat paint) & exhaust reinstall............3" stainless works is a PITA to put back on with 1 person but its on and all I need to do is to top off the trans fluid, drop it off the lift and go for a spin........hope all works ok
Old Jan 2, 2007 | 01:07 PM
kromberg's Avatar
kromberg
So how much was the Turbo 400 package? Looks great
Keith
Old Jan 3, 2007 | 01:00 PM
Cruise-In V Veteran
NCM Ambassador
Originally Posted by kromberg
So how much was the Turbo 400 package? Looks great Keith
No turbo 400 here...........my days of no OD are gone
Terminator 3 4L60E Rossler w/ T-brake & vacumn modulated
Old Jan 3, 2007 | 03:23 PM
kromberg's Avatar
kromberg
Really, that did not look like a 4L60E. How much rwhp do you expect that to hold?
Keith
Old Jan 4, 2007 | 07:05 AM
Cruise-In V Veteran
NCM Ambassador
More than I can throw at it..............right now. it should take 650 w/o issue.
The level 2 took my 10K hard miles, 250 1/4 mile passes, road racing, auto xing and 700 mile trips & 500 rwhp/tq ........and I have no idea how it was treated prior to me owning it(came in the car).
Took it out for a spin last night ~breaks the 345/35/18s loose at 50mph in 2nd.........no loss of power for sure
Here are a few pics of the old TCS converter Stator and pump John didn't use in the build-up:
To 97 going back together......
