Power Steering Castor differences
Old Dec 26, 2006 | 06:34 PM
Roach5337's Avatar
Roach5337
Default Power Steering Castor differences
When GM changed the castor of Steering Gear boxes on '98s to a more aggressive stance over the '97, I'm told this was to help improve driveability on rutted roads.
Does anyone know if this change was made to the gearbox? Or is hole (mount) placement different on the frame, allowing for a steeper mount on the vehicle?
Finally, anyone ever heard of swapping out gearboxes from the early C5 to the later versions to improve driveability?
Happy New Year!
Old Dec 27, 2006 | 12:58 AM
Bill Dearborn's Avatar
Bill Dearborn
Happy New Year!
????????? WTF
Caster is a function of wheel alignment. It is adjusted by moving the control arms. The steering rack is bolted to the cross member and the same part number is used for 97-04 C5s. Check the part number and price at Gene Culley's new parts site:
http://www.trademotion.com/partlocat...03&catalogid=1
Bill
Old Dec 28, 2006 | 12:37 AM
Roach5337's Avatar
Roach5337
Main reference is from, "Corvette, Sportscar Superstar" book, Copywrited in 2005, written by the editors of Consumer Guide. On page 343, second column, 3rd line, "In addition, the power-steering's castor angle was increased for better tracking..."
A call to the local GM dealer revealed a service tech and their boss with no clue. A visit to a mechanic in tampa who works exclusively on these beauties concurred with the statement, but set the tone straight with a similar "WTF"... and recaged my eyeballs and noggin' in roughly the same manner on an '04 being rebuilt...and a '98... no difference in actual placement of the steering gear box...I think there was a "dufus" at the end of schooling.
I appreciate the point-out...Once I get over the Peyote rush and out of rehab, I'll buy you a beer for the reply.
Old Dec 28, 2006 | 01:51 AM
Bill Dearborn
OK now that you provided that marketing reference I think I can answer your question. In 97 the Caster was spec'd at +6.1 degrees + or - .5 degrees. In 98 they changed the spec to a service allowable range going from 7.4 to 6.4 with the service preferred spec being 6.9. If you have a 97 you can set your alignment to the newer spec since there were no mechanical changes made to the 98s front suspension.
Bill
Old Jan 2, 2007 | 07:36 PM
Roach5337's Avatar
Roach5337
Perfect. Thanks for the help. I'm going to drop the car off for an alignment and was curious if there were options. I'll go with the '98 specs.
Thanks again!
To Power Steering Castor differences
