Shocks Affect Steering and Road "Feel" ?
Old Dec 27, 2006 | 11:06 AM
lloaf's Avatar
lloaf
Default Shocks Affect Steering and Road "Feel" ?
One of the things I have always wanted to improve about my Vette is its steering and road "feel". This concept is kind of hard to define. It is not handling per se, or even confidence in going around corners. It is more a feeling of being at one with the road---almost a go kart like effect. My question is whether going to coil overs or Bilstein's would enhance this effect ? The reason I ask is that on a 300zx twin turbo I had, I went to Tokico 5 way shocks, and it definitely helped produce this effect. Thanks.
Old Dec 27, 2006 | 11:14 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Shocks will help but it may also be tire and alignment issues.
Old Dec 27, 2006 | 11:50 AM
Lancer033's Avatar
Lancer033
A properly setup stock C5 should feel pretty good. Put some good tires under it (regular non-runcraps) and make sure the alignment is good (slightly more aggressive than stock) before you start messing with the other stuff.
Old Dec 28, 2006 | 10:27 AM
Brad@RevXtremeAutoSports's Avatar
If money is not an issue, go with the coil overs and t1 sways. Get the poly rebuild kit for the front end, Kumho tires and you will grin from ear to ear.
Old Dec 28, 2006 | 09:32 PM
waupachino's Avatar
waupachino
I just put the Hotchkis sway bars and Bilstein Sport shocks and there is a big difference in the road feel. You can definitely feel the road better and the car is much better in the turns. I had also dumped the runcraps for Michelin PS2s already.
To Shocks Affect Steering and Road "Feel" ?
