headlight problem (not gears)
Old Dec 27, 2006 | 07:33 PM
A.Fry's Avatar
A.Fry
Default headlight problem (not gears)
i noticed last night that my drivers side light was bounceing around and i could pull it up a little more higher than all the way up. i took it apart and found the pin that attaches the lift motor arm to the light assembly was off. luckily the pin was still laying inside the front bumper cover. i felt around and found a small plastic bushing still kind of in the assembly but it was split. i went to the stealership and they told me that there was'nt a replacement part sold seperately i would have to buy the entire assembly $670.00 WHAT IS WRONG WITH THOSE PEOPLE? is that part a bushing or a pin retainer? it's ID was the same as the OD of the pin with a tiny collar. does anyone have a solution? thanks
