Headlight won't popup
Old Dec 27, 2006 | 10:26 PM
lanceg1041's Avatar
lanceg1041
Default Headlight won't popup
Hi all, 2000 c5, my drivers headlight occasionally will not popup until I cycle it 2 or 3 times. I don't hear any grinding so I don't think it's the gears. The light goes on even if it doesn't popup. Any suggestions would be helpful. Thanks.....Lance
Old Dec 28, 2006 | 12:13 PM
thevelvetglove's Avatar
thevelvetglove
I had the same thing and it turned out ot be the gears. Don't be fooled by the lack of a grinding noise. In the end I replaced both motrs through FRED BEANS for half the price of GM
Old Dec 28, 2006 | 12:31 PM
rcknusa's Avatar
rcknusa
I have the exact same problem with my right headlight on 2000 coupe. I know the gear is not bad because I took the cover off and found the brass gear is fine, the rubber piece in there is torn a little but don't know if that has anything to do with the problem. I just saw this for the left headlight in another post. It is specifically for the left and not the right but don't see why it would not be applicable.
Here is a TSB that came out quite a while ago that fixed my problem very similar to what you describe. Seems to be almost exclusive to the 2000 yr model. Replacing the insulator tips on the mounting bracket travel stop tabs works like a champ. The TSB has a diagram illustrating the fix.
http://corvetteactioncenter.com/kb/q....php?qstId=217
2000: Service Bulletin: Left Headlamp Door Does Not Stay Closed
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition: Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction: Important: he following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number
Description
Qty Per Vehicle
11505463
Washer
3
16524060
Insulator
2
Old Jan 31, 2007 | 01:52 PM
lanceg1041's Avatar
lanceg1041
hey Velvet Glove.
You were right. The gear finally started making that awful ratcheting noise. I ordered Rodney's brass gear rebuild kit for $50 and rebuilt the motor. Easy job and saved me a ton.
Thanks,
Lance
To Headlight won't popup
