thermostat question
Old Dec 27, 2006 | 11:02 PM
Corvette Don's Avatar
Corvette Don
Default thermostat question
I know, I know.......Ive noticed my car getting up to 228 in the city, is it ok to get aa 180 or even a 160 deg thermostat without any problems?
Old Dec 27, 2006 | 11:39 PM
robvuk's Avatar
robvuk
I hope you realize that's not going to reduce that 228 temp in the city. This is perfectly normal.
Old Dec 28, 2006 | 12:04 AM
Corvette Don
I figured it was but would it help performance wise to switch to the next lower deg thermostat?
Old Dec 28, 2006 | 12:48 AM
fdxpilot's Avatar
fdxpilot
Not unless you get your fan operating temps adjusted. You will just have a wider range of operating temps, 160-230, instead of 190-230.
Old Dec 28, 2006 | 12:56 AM
PierEagle's Avatar
PierEagle
As ROBVUK sez, if 228 is the normal operating temp for your car, putting a lower rated thermostat in is not going to lower that operating temp. All it will do is open up at a lower temp and take slightly longer for the temp to hit 228, but it will hit 228 and I believe that is within the range suggested for the motor. Some may disagree but, I think if you operate the engine at too cool of a range, you actually hinder performance.
If you get an actual overheat situation then you've got a cooling system problem, hoses, leak, blockage, etc., which may or may not include a thermostat that's stuck closed.
Cheers
Old Dec 28, 2006 | 09:34 AM
gpracer1's Avatar
gpracer1
Just have your fans programmed to come on at 2XX <-----insert your preferred temp here.
Old Dec 28, 2006 | 08:54 PM
kevin40zx's Avatar
kevin40zx
I put a 178deg on mine and noticed around an 8deg drop in temps while cruising. But it will still heat up around 225 while sitting still.
Old Dec 28, 2006 | 11:11 PM
65GGvert's Avatar
65GGvert
Try cleaning the radiator (in front and between the radiator and condensor fins) before you try the thermostat. Mine runs around 200 most of the time, never has gotten to 228. As you have already heard, just putting in a lower thermostat will only alter the temp your thermostat opens, not the temp your car runs in traffic. You need good air flow through the radiator to lower that. Make sure your fans are coming on, too.
Old Dec 29, 2006 | 04:59 PM
99 vett babycar's Avatar
99 vett babycar
To thermostat question
