C5 Climate Control dim/dark display fix
Old Jul 10, 2017 | 07:45 PM
  #601
LDOVET's Avatar
LDOVET
Cruising
Originally Posted by RamHemiTX
Fixed mine this weekend in my "New To Me" 04 Z06 CE. Thanks for the how to!
Fixed mine a few weeks ago, worked great. I had the soldering done for free as "training" for one of my micro miniature repair techs. The luster of my accomplishment was tarnished as I snapped the shifter cable changing out the broken/brittle piece on the shifter. When "they" say, "be careful that you don't snap the outer cable housing", they weren't kidding. $900 + dollars later, fixed.
Old Jul 11, 2017 | 09:46 AM
  #602
Hiram's Avatar
Hiram
Great ideas using the clamps I did mine without using clamps and one of the resisters started to slide a little but I did get it back in place and cleaned off a little solder that slid with it.
In the end evertything worked great. Your way is a much better aproche to the problem.
Old Jul 21, 2017 | 02:14 PM
  #603
Barjack's Avatar
Barjack
Navigator
I just completed this yesterday and the display is bright and clear. I'm impressed.
The 241 chips are not attached too well and when you hit the chip with a fine tip soldering iron - they move easily. Also my chips were in different locations not in two rows of 4.
Old Jul 21, 2017 | 04:50 PM
  #604
wcsinx's Avatar
wcsinx
The easiest way to deal with soldering down components like that is to just tape them down with kapton (high temperature) tape. Don't use masking, packing, scotch, etc. tape which will just melt or burn.
Old Aug 4, 2017 | 05:49 PM
  #605
J. Kent's Avatar
J. Kent
I know the original post was over a decade ago but I'm new to Corvettes and new to the forum, so THANK YOU Genocid!
Just got an '03 C5 with under 44K miles The only issues are some ripped stitching on the driver's side bolster and the dim HVAC display. There is a local upholstery shop that will replace the vinyl panel and rebuild the cushions for a reasonable price. I'm really happy to see I'll be able to fix the display myself for free!
Old Sep 9, 2017 | 05:28 PM
  #606
J. Kent's Avatar
J. Kent
Fixed it! Thank you Genocid! As Barjack noted, the resistors will move when you melt the solder, so I followed a tip from another member and used a small plastic clamp to hold each one in place as I soldered. Worked great! Total project took about 2 hours. YMMV.
Old Oct 2, 2017 | 02:35 PM
  #607
37pat's Avatar
37pat
Did my wife's yesterday. Added solder at places, not at others. But the outcome was a great success, and I think the resisters move when you heat the not-broken end first. But, isolating the breaks ahead of time is likely not worth the effort. The clamp looks like a good idea as well. Wish I'd thought of it. Currently HF has a very small 30 Watt soldering iron on sale for about $4.00. I used one of those. All is now good.
Old Apr 26, 2018 | 01:33 PM
  #608
BOUT X's Avatar
BOUT X
Corvette Cowboy
Well 18 yrs later time to do mine after read the first page I see there are other things to look at out of the 30 or so pages is there a post I should read that’s not on the first couple post. TIA for any and all help.
Pops
Old Apr 26, 2018 | 03:33 PM
  #609
J. Kent's Avatar
J. Kent
Pops
Nope--the first page tells it all. Carefully follow the instructions to disassemble everything, starting with the waterfall (for verts).
2 bits of advice:
  1. Use a real soldering iron and solder meant for electronics. A 40 watt pencil iron will do. A gun is too big. Do NOT use any kind of "cold" solder.
  2. use a small plastic clamp with a long reach like the one in my photo (post #606). If you don't the resistors will slide around. They do not have leads that go thru the board (like all the other resistors on there), just pads that sit on the board. Poor design that causes the breaks IMO
The great thing about this fix (besides being totally free) is you can remove the module, take it indoors and solder it on your bench (or kitchen table). Don't take any shortcuts with battery-powered soldering irons or cold solder. Do it right. The trickiest part is preventing the resistors from sliding around.
I'll add my vote: THIS SHOULD BE A STICKY!
-Kent
Old Apr 26, 2018 | 04:12 PM
  #610
BOUT X's Avatar
BOUT X
Corvette Cowboy
J. Kent thanks for the info my job is to get it out and get the parts together here at work we have a full service circuit board dept. that will do all the soldering 👍
Thanks again
Dale
Old Jun 2, 2018 | 05:18 PM
  #611
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Another successful display restoration.
My additional $0.02: Have fine-point tweezers at hand before you start. When (not if) a resistor slides, you'll be able to easily put it back in place. In fact, after my first "slider," on all the rest of the resistors I prevented sliding by lightly pressed down on the center of the resistor with the tweezers before touching it with the tip of the soldering iron. If I needed more solder, I'd pull up the iron, put a dab on the iron tip, put the tweezers back on the resistor, then bring the iron back into contact. Less than 5 minutes to solder all 16 pads, going very slow. The display now matches the radio display brightness for the first time in more than a decade.
Old Sep 10, 2019 | 08:20 PM
  #612
Harleyyac's Avatar
Harleyyac
Thx ! Picking up 03 on 9/12.I have had experience removing dash on a few cars. I'll tackle this hopefully in the winter.
Old Jul 14, 2020 | 08:25 AM
  #613
Autoeng's Avatar
Autoeng
Videos I found that show the fixes. YellowVette04 has a couple of vids,one showing how to do the display, one how to do the light bulbs
Dim Display Fix -
Replace Backlights Fix -
Old Jul 14, 2020 | 11:49 AM
  #614
LDOVET's Avatar
LDOVET
Cruising
Thanks for the videos. The dim display fix worked great, wish I had done the bulbs at the same time, didn't realize a few were out until after putting it back together. I need to replace the little orange gear indicator so I'll do the lights then.
Old Jul 14, 2020 | 02:45 PM
  #615
1997 C5's Avatar
1997 C5
I did the soldering of the relays but it lasted roughly 6 months. Recently the screen went out again. Should i try respldering the relays or screen shot?
Old Nov 2, 2020 | 10:11 PM
  #616
streamliner's Avatar
streamliner
Can anyone tell me where to find the 240 ohm resistors? I’m missing one of the eight. I have the climate control removed and disassembled.
thanks in advance
Old Nov 3, 2020 | 10:43 AM
  #617
J. Kent's Avatar
J. Kent
thanks in advance
Maybe this? https://www.mouser.com/ProductDetail...MNsGA4gaTrM%3D
Or these?
Amazon Amazon
What you need is a surface-mount 240 ohm resistor but I'm not sure of the wattage. 1w seems safe if the physical size works. Panasonic is always a good choice. The ones on Amazon are a lot of 50 pcs.
Hope this helps. Do you have a local electronics parts store?
To C5 Climate Control dim/dark display fix
Old Nov 4, 2020 | 10:16 AM
  #618
Capt Mike's Avatar
Capt Mike
Default Electronic Parts
TRY these, all trusted long time businesses. The last two specialize in Hobby Tools, kits, modules, sensors etc. and have training Videos. Check out the Soldering....
Good Luck,
Michael.
Jameco
https://www.jameco.com/shop/keyword=...ctronics-parts
Newark
https://www.newark.com/homeb?adobe_mc_ref=
Mouser
Difikey
https://www.digikey.com/
Adafruit
https://www.adafruit.com/
Sparkfun
https://www.sparkfun.com
Old Dec 29, 2020 | 03:42 PM
  #619
minuteman048's Avatar
minuteman048
Just got the car and is the first problem I encountered. With mine, I start the car in the garage and it's nice and bright, but as soon as I back out into the light it goes dim on me. Figure its those solder points.
Old Dec 30, 2020 | 04:00 PM
  #620
Autoeng's Avatar
Autoeng
That isn't the problem. Might not be any problem at all because if they are bright in the garage then they are working correctly. Do you have the Daytime Sentinel option on the DIC selected? If you do try turning it off and see what that does.
