CLB doesn't work with recall?
Old Dec 29, 2006 | 01:05 AM
Scott Farmer's Avatar
Scott Farmer
Default CLB doesn't work with recall?
So, the notorious fuel-cut at 2mph happened to my friend while driving my 02 Z06 about a month ago, although he let it sit and everything worked after 10 minutes.
I took it to the dealer and asked about the recall (this was before I discovered Corvette Forum's experience), but they said it was already done on my car. So, I decided to do the CLB from Corvettes of Houston.
I went through their install instructions, but could not get the steering column lock to disengage with the 12V cigarette lighter adaptor. I checked the OEM cables/plugs and found the white wire, instead of the orange wire, indicating that they had done the recall.
I knew that they did the recall, but I wasn't sure which one, because I know that GM has issued several recall notices.
So, my questions are:
1) Is there a way to use my CLB from CoH to prevent the issue from coming back, even though I've had one of the recalls done?
2) If not, does it sound like I've had the most recent (Feb. 2006) recall done? With the key out, my steering wheel locks. If I get the new recall done, will it prevent problems?
Old Dec 29, 2006 | 01:13 AM
FRCTony's Avatar
FRCTony
1. Yes
2. No
Call Corvettes of Houston first.
I believe you can just unlock and pull the BCM fuse.
Old Dec 29, 2006 | 09:49 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
If both recalls were done, you need to have the pcm re-flashed to remove the useless programming by GM. Contact Corvettes of Weschester and ask for Chuck.
Old Dec 29, 2006 | 12:11 PM
Scott Farmer
So, I did some detective work and found this:
Recall 04006 was done on December 17, 2004. This is the last recorded recall for the "electronic column lock" issue. So, they haven't done the most recent one.
I called CoH and they weren't able to give me any help. Basically, they said that given what I told them, the 12V adaptor should have unlocked the column lock...but it wasn't. Is my only option still Chuck at CoW? Should I let my dealer complete the most recent update to the recall?
Old Dec 29, 2006 | 12:17 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
no need for cow if the 2nd recall wasnt done. i had my clb installed even with the first recall done. although mine didnt come with a 12v cig adapter cord. i was instructed to pull fuse 23 during installation. my clb kit came from thunder racing.
Old Dec 29, 2006 | 12:23 PM
Scott Farmer
So, you just pulled fuse 23 and connected the new box in?
Old Dec 29, 2006 | 01:31 PM
Mrs. CoW's Avatar
Mrs. CoW
Default Some useful info
Here is what i found after a short search on the forum, it was posted by Chuck CoW.
For MN6 & MN12 cars only:
1997
Reprogram Only
1998 built through 5/25/98
Reprogram Only
1998 built on or after 5/28/98 (CSC 01044 was performed)
Reprogram Only
1998 built on or after 5/28/98 (CSC 01044 was not performed)
Install wire kit (part#88952428) and reprogram
1999-2000 and CSC 01044 or TSC 01--02-36-008 was performed
Reprogram Only
1999-2000 and CSC 01044 or TSC 01--02-36-008 was not performed
2001-2004
Reprogram Only
For A4 cars only:
1997-2000 A4's
Install wire kit (Harness K), remove and discard lock plate, install the "cam orientation plate" where the lock plate previously resided. No BCM flash required.
2001-2004 A4's
No Change Required - they didn't install the Electric Column Lock (ECL) on those years, in the U.S., after experiencing so many problems.
Maybe it will come in handy.
Old Dec 29, 2006 | 01:42 PM
Scott Farmer
Is this what Chuck at CoW does? Or are those the dealer actions?
Old Dec 29, 2006 | 02:19 PM
Mrs. CoW's Avatar
Mrs. CoW
This was info taken from the GM website, and are recommandations, Chuck can do any of this actions, including the computer reprogramming that would ensure you would not have this problem again.
Old Dec 29, 2006 | 02:29 PM
thehammer69's Avatar
thehammer69
Call me crazy, but I don't see what is so unique about what COW does to eliminate GM's reprogramming. I'm new to using HPtuners, but it seems that any HPtuner having tuner can just flash in a pre-recall OEM program that can be found in the bin repository. Or they can even take that Pre-recall OEM program and modify it for more power and flash it into your PCM. I have nothing against COW but it seems to me that they aren't really doing something unique here.
Hammer
Old Dec 29, 2006 | 02:52 PM
Mrs. CoW's Avatar
Mrs. CoW
We are talking column lock here... Whatever he does, works, and the dealer is not doing, because people seem to have repeat problems with something that it should have been fixed in the first place.
Also, i have not seen anybody else offering this service, yes installing the cable (i can do that) but the neccesary computer repograming that goes with it, no. I am not saying he is the only one that can do it or unique (even if he is) but he is the one that offered this service and can do it corectly, witch makes all the difference.
Information never hurt anybody, uncalled for or unnecessary opinions/ bashig, does.
Old Dec 29, 2006 | 03:16 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Here's How it works....
Hammer
Hey Hammer.....
Here's the deal..... The colum lock logic is not in the PCM, it's in the BCM and you can not re-flash it with HP TUNERS. Also, you can not re-program the BCM....I can. Installing the CLB permanantly prevents the col lock from engaging....... Most importantly, now that the column is not physically locked (and you can ALWAYS steer the car)..the next obstacle is that if the CLB or the BCM and wiring farts...The BCM commands the Engine Control Computer to cut fuel at only 2 mph. Now, even though the col is not locked...YOU ARE STILL STUCK.
What I do, which is different, is tell the pcm that the car was not outfitted with the locking column option......SO, when the BCM sends the signal to the PCM to cut fuel, the command is ignored and the car continues to drive.....
You might possibly get the "service column lock" message if I don't reprogram your BCM, but....YOU WILL NEVER GET STUCK my way...I make it impossible to get stuck.
Call me if you need help,
Chuck CoW
Old Dec 29, 2006 | 03:22 PM
thehammer69
I know you are talking about the Column Lock....
I wasn't bashing, just stating something that seemed obvious to me that nobody else seemed to pick up on. Why that bothers you...
ON EDIT: Chuck's explanation of how the change is actually in the BCM cleared up my misconception.
Hammer
Old Dec 29, 2006 | 03:23 PM
thehammer69
Originally Posted by Chuck CoW
Hey Hammer.....
Chuck CoW
Thanks Chuck...I now have a better understanding.
Hammer
Old Dec 29, 2006 | 04:36 PM
87SAM's Avatar
87SAM
Have you checked that your 12V cigarette lighter has power?
Old Dec 30, 2006 | 02:18 PM
Scott Farmer
Yep, I tested it using the cigarette lighter...it works.
I've only had one recall done (not both), so the going wisdom is that I should be able to use the CLB from CoH. And yet, I couldn't unlock the column with the 12V adaptor.
Ikester mentioned pulling fuse 23 during his installation of a different (Thunder Racing) CLB kit. Can anyone post their instructions from Thunder Racing...or tell me what to do differently?
To CLB doesn't work with recall?
