Fogs lights on with high beams also?
Old Dec 30, 2006 | 12:28 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Fogs lights on with high beams also?
Is it hard or complicated to change the wiring, so that the fog lights will work when either the low or high beams are on? Thinking of getting some Piaas and want them to work on the high beams too.
Thanks,
Clayton from Las Vegas
Old Dec 30, 2006 | 12:35 AM
nuke61's Avatar
nuke61
If you're getting PIAAs, you can hard wire them using the PIAA relay and have full control over when they are lit or not. If you're going to use the stock foglight switch and relay, I've never seen anyone show how to have highs and fogs on at the same time.
Old Dec 30, 2006 | 05:56 AM
I would guess anything is possible, but haven't seen any posts about doing this either.
Old Dec 30, 2006 | 12:23 PM
Bubbletop409's Avatar
Bubbletop409
A PAINLESS WIRING relay part # 30802 will keep your fog lights on when the highs are on. Tap the relay trigger wire into the high beam circut, and the feed wire from the relay into the fog circut, you will also have to run a ground wire and hot wire to the relay. You can also use the same part # relay to keep your low beams on when you are running the highs, in that application the relay wires are color coded the same as the C5 headlight circut, I have this relay on my C5 headlights and have had the same on two GM pickups with flawless performance.
Old Dec 30, 2006 | 10:52 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Could you give me a little more detail. I'm not sure what you are describing. :o
Old Dec 30, 2006 | 11:21 PM
jrprich's Avatar
jrprich
I would like to know how to wire this up as well
Where can one get the relay mentioned ?
Old Dec 30, 2006 | 11:22 PM
Bubbletop409
The kit consists of a relay with a 30 amp rating, and the necessary wiring to make it functional. The trigger wire taps into your high beam circut, when you turn on the high beams the relay closes and delivers current to your fog lights via the feed wire from the relay. You also need to run a hot wire from a 12 volt source thru a fuse to the relay, and a wire from a good ground source to the relay. Very simple to do, I mounted my relay inside the battery box, and ran the wires to the headlight circut, under the coolant tank and made the connections there, totally hidden when complete. The relay kit is available from the usual mail order speed shops for about 20 bucks, come with complete directions for the high beam circut, to do the fog lights all you need to do is identify the positive wire in that circut. Personally I think your better off having the ability to have high/low on at the same time rather than high/fog, but thats just my .02.
Old Dec 30, 2006 | 11:51 PM
jrprich's Avatar
jrprich
Default Painless
Try searching Google for Painless 30802 Relay Kit.
You will find lots of pricing and a few How To's as well.
Seems like you could just T off the switched wire to the Low Beams to the Fogs and get High + Low + Fogs when you turn on your High Beams?
Thanks Bubbletop409 for the info,
Old Dec 31, 2006 | 01:29 AM
Bubbletop409
Ya you could do that, but then you could not control each light independently, relays allow you to turn on other circuts without electrical feedback.
Old Dec 31, 2006 | 11:31 AM
jrprich's Avatar
jrprich
You are correct........but I meant using the Painless relay as you suggested but just T the Low Beams and Fogs so all three come on with Brights.
Old Jan 1, 2007 | 06:38 AM
cliff_ford's Avatar
cliff_ford
By the way on Euro export C5's the fogs can be on with low or high beam.
Old Jan 1, 2007 | 04:02 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
How is the wiring different?
Thanks,
Old Jan 1, 2007 | 11:07 PM
Bubbletop409
Sure you could "T" the feed wire from the relay if you wanted everything on in the high beam mode. One thing I would caution you on though, is to verify you would not be overloading the relay. As I stated previously the rating on the relay is 30 amps. I would locate the fuses for the high beam and fog circuts, add their amp ratings together, and if you get 30 or less I would say you are good to go. If your over the 30 amp mark, you could also run seperate relays for each circut.
Old Jan 2, 2007 | 12:18 PM
cliff_ford's Avatar
cliff_ford
Thanks,
I believe the wiring is the same, I think the software in the BCM is different.
Old May 25, 2025 | 04:58 PM
3R1$C's Avatar
3R1$C
Can the software in the BCM be changed? That would obviously the simplest modification without any wiring change? Over in Europe, the fog lights have to be independent. They are not allowed to be switched off when the high beams are on.
Also, is there a wiring diagram somewhere? The fog switch yellow light and switch is off when the high beam is on. We do not want the fog lights on every time the high beams are on, only when the fog light switch is depressed.
Old May 27, 2025 | 04:49 PM
3R1$C's Avatar
3R1$C
Solution posted here
https://www.corvetteforum.com/forums...igh-beams.html
Old May 27, 2025 | 06:24 PM
Dads2kconvertible's Avatar
Dads2kconvertible
Originally Posted by 3R1$C
Your "solution" is for a C6?
Old May 28, 2025 | 09:21 AM
3R1$C's Avatar
3R1$C
C5 2003
Old May 28, 2025 | 11:20 AM
Dads2kconvertible
C5 2003
Then why post it in the C6 section?
To Fogs lights on with high beams also?
