Help! c5 is completely ****ed!
Old Dec 30, 2006 | 09:36 PM
Kale's Avatar
Kale
Default Help! c5 is completely ****ed!
04
I had to unplug the little silver computer in the back rear storage compartment, as well as unplug the relay boxes in the doors. I reconnected them, and turned the car on, and got a myriad of messages:
REDUCED POWER
SHOCKS INOPERABLE
LOW TIRE PRESSURE
LOW FUEL
(The last 2 are certainly not true.)
And the car won't start - It just clicks.
Old Dec 30, 2006 | 09:48 PM
Shark Racer's Avatar
Shark Racer
Sounds like you've got problems.
Old Dec 30, 2006 | 09:58 PM
Kale's Avatar
Kale
Thanks for clearing that up.
40 BCM NO COMM
58 SDM NO COMM
60 IPC NO COMM
99 HVAC NO COMM
AO LDCM NO COMM
A1 RDCM NO COMM
BO RFA NO COMM
10 PCM NO COMM
Old Dec 30, 2006 | 10:07 PM
vette dan's Avatar
vette dan
Vette Dan
Sorry . But what silver box in rear storage compartment???????
Unless i'm blind nothing in mine but my gloves.
Old Dec 30, 2006 | 10:08 PM
DngrZne's Avatar
DngrZne
Prob the computer for the magnetic shocks.
Old Dec 30, 2006 | 10:09 PM
Kale's Avatar
Kale
yes.
any suggestions to fix this crap?
battery was disconnected for about a week, but reads 11.8v
Old Dec 30, 2006 | 10:31 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by Kale
yes.
Try charging your battery to full capacity, 11.8v may be too low..
Old Dec 30, 2006 | 10:44 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Old Dec 30, 2006 | 10:45 PM
Kale's Avatar
Kale
k got the battery on the chargerr
fwiw, it says HVAC NO COM, but the HVAC works fine
if i start the car, it dies immediately. Car thinks there is no fuel.
Old Dec 30, 2006 | 10:47 PM
chriswtx's Avatar
chriswtx
try erasing all the codes...
Old Dec 30, 2006 | 10:51 PM
Kale's Avatar
Kale
as soon as i do, they crop back uip
fwiw, it wont show tire pressure sensor, it won't read the fuel, but it WILL show oil temp
Old Dec 30, 2006 | 10:54 PM
gpracer1's Avatar
gpracer1
Disconnect the battery for 10 min. Make sure it is charged up real good. Then try again. Hopefully your battery is still good.
Old Dec 30, 2006 | 10:57 PM
chriswtx's Avatar
chriswtx
also check for a ground that you maybe missed connecting back..
Old Dec 30, 2006 | 11:00 PM
Kale's Avatar
Kale
I didnt undo any grounds, just basically took the car apart for a stereo/deadening install. Only unclipped connectors.
Old Dec 30, 2006 | 11:26 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
These cars act really really weird when the battery is low or if the battery is bad. A battery can even check good and still be bad. As stated above, make sure it is FULLY charged. Other than that, go get yourself another battery and try it. If it doesn't work, you can always bring the battery right back.
Old Dec 30, 2006 | 11:33 PM
SLPRC5's Avatar
SLPRC5
excellent point. Also as mentioned once you have a fully charged batt. disconnect it for about 10 minutes. PCM will reset and then try to delete all the codes.
Good luck...
Old Dec 31, 2006 | 10:50 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default tire pressure readout
fwiw in my 01, the tire pressures are no good unless I drive it halfway round the block so u probably should discount that one
take the battery out of your other car or use jumper cables...less driving around
you probably got those messages because only part of the things that report to the ecm lost power. disconnecting the battery and reconnecting it again might do the trick
sometimes capacitors are used to keep circuits alive, and connecting and disconnecting circuits sometimes bleeds them off
To Help! c5 is completely ****ed!
Old Dec 31, 2006 | 12:29 PM
Kale's Avatar
Kale
Well, I let it charge all night (disconnected from the car)
hooked it up this morning, and it's the same problem.
What else could it be?
Does anyone know where the PCM is grounded? Maybe i knocked the ground out when I had the battery tray out.
Or what fuse controls the tire pressure sensor readers, fuel gauge?
Old Dec 31, 2006 | 12:41 PM
RFJohnston's Avatar
RFJohnston
From: Russellville, Kentucky 1967 Sting Ray & 2001 C5
Test the battery... sounds like it's bad to me.
Old Dec 31, 2006 | 12:54 PM
Kale's Avatar
Kale
I put my SAAB's battery in the C5, and it has the same prob lem still.
saab battery is about 1.5 years old.
What fuse would cover this?
* No fuel gauge reading
* No tire pressure reading
* Fails communication to all computers
I checked "PCM-B" under the hood, but it was intact.
