Harmonic Balancer
Old Jan 16, 2007 | 10:53 AM
thehammer69's Avatar
thehammer69
Originally Posted by Hawkdriver
Got the Steering Rack out. Can't get the bolt loose......yet! Did find a redneck (I'm from Alabama) way of holding the balancer from spinning on an auto. I put a 1 X 1 block of wood about 1 foot long where the steering rack was. Then shoved a screw driver in one of the balancer holes around the outside. Rotate untile the screwdiver is up against the block of wood and go to pullin'! My problem is the loctite. Got some liquid wrench on it right now. My impact had no effect on that sucker, nor did pulling with a breaker bar. Any suggestions?
Put a pipe on that breaker bar or get an even more powerful impact wrench.
Hammer
Old Jan 17, 2007 | 11:31 AM
jeanlucpicard's Avatar
jeanlucpicard
When pulling the harmonic balancer pulley what worked for me was to put both rear wheels on the garage floor, set the emergency brake, chock both sides of the rear wheels, put the car in 4th gear (MN6) and use a breaker bar with 3ft cheater pipe. The bolt freed up easily. Then I jacked the rear back up and went to work on pulling the balancer and removing the front engine cover, etc. I did the same thing when I installed the new balancer and new bolt but was unable to get the 140 degree rotation so I gave the new bolt the old steriod jerk until the torque wrench clicked at 220ft lbs and the disc in my lower back clicked
I believe you can do a similar method on an automatic by putting the car in 1st gear.
Good luck.
Old Jan 19, 2007 | 03:02 PM
Hawkdriver's Avatar
Hawkdriver
Got it, blew out my left nut though!
Old Jan 20, 2007 | 04:13 PM
BamaC5R's Avatar
BamaC5R
Hawk, did that fix your squeaking sound? Sounds like I may be in the same boat as you. I just do not understand how that could cause the squeaking sound.
Jimmy
Old Jan 20, 2007 | 04:42 PM
Tmyz 2K's Avatar
Tmyz 2K
Jimmy
I had the sqeak you speak of, and the pulley was the answer. my guess is that when the pulley wobbles, the belt runs up against the side of the belt channel on the pulley and causes the squeak. a new belt didnt fix the squeak, but a spray of wd-40 did the trick for a brief few seconds.
and i just replaced my pulley this past thursday. sqeak free and Daily driving it.
Old Mar 20, 2007 | 09:54 PM
xlr8shn's Avatar
xlr8shn
When my car squeaked, it turned out to be the tensioner on the a/c belt.
To diagnose, I ran the car with one belt at a time. Only squeaked when a/c belt was on. I squirted some WD40 on the tensioner and the squeak temp went away. $60 later at the auto parts store and I had a replacement tensioner and squeak has not reappeared. Replaced both belts while there anyway.
Old Feb 10, 2011 | 01:23 PM
ChromeC5's Avatar
ChromeC5
Originally Posted by Corvette-Chris
Mine started to wobble 3,000 miles after a cam install and it shredded the belt. i forgot to put lock tight on it....yeah i know I work at a garage so we have more than your average household tools so i didnt pull the steering rack back out. Needless to say it has been fine for many more miles. Sorry to hear that....and yes use gatorback belts, they are the quietest i have heard.
Chris
Any instructions on how do do this procedure without removing the rack?
Old Feb 10, 2011 | 01:31 PM
lucky131969's Avatar
lucky131969
When you find that information, make sure you share it
Old Feb 10, 2011 | 01:46 PM
ChromeC5's Avatar
ChromeC5
Is there a write up with pictures? I've done searches and looked at the LS1howto writeup and then see on this forum that there should be corrections to the LS1howto writeup.
Looking for a very nice, straight forward, easy to follow write up that everyone agrees on if one exists.
I do have the GM service manuals but I also know that there are shortcuts as in not fully removing the steering rack but only the right side and pushing it forward. In other words, I'm looking for a clean write up with practical short cuts, not half a** short cuts.
Old Feb 10, 2011 | 01:55 PM
lucky131969
Can't help you there. The service manual is a no brainer, and it's what I used. Piece of cake.
Old Feb 10, 2011 | 02:30 PM
Cratecruncher's Avatar
Cratecruncher
Chrome,
You're right, the rack can be repositioned out of the way without dropping the subframe to get it all the way out.
But the "shortcut" people claim you can r&r the balancer by chocking the wheels and setting the parking brake is nonsense. Many of those installs have come off since this thread was started.
Do yourself and your car a favor and buy a J 42386-A. It's a cast steel tool ($85) that bolts into the starter mounting holes to lock the flywheel in place so you can do the job right. The reason everyone makes this install out to be so hard is because they're not doing it right. The balancer doesn't get seated properly and the bolt isn't sufficiently tightened. Also, you shouldn't need to pin the crank on a normal powered car if you install the balancer and torque the bolt correctly. Trying to remove the Balancer bolt without the flywheel lock felt like I was pulling on a rubber band. My breakover was twisted all the way across the engine compartment and the bolt hardly had any torque on it. With the J-Tool in place the bolt came right off- with no heat either. Install using the GM bolt ($6) was a snap too! Again, get that tool. Use it once and resell it on eBay to another C5 owner.
Old Feb 11, 2011 | 04:20 AM
00Corvette's Avatar
00Corvette
Do yourself another favor and use some HEAT to install the new balancer...stick it in the oven on 200 for like 20 minutes or something.
If I had seen this sooner, I would have told you to heat the center hub of that balancer with a torch for a few minutes..it would have slid off WAY easier. AND broke the locktite loose.
Donnie
Old Feb 11, 2011 | 06:32 AM
  #33
guido7834's Avatar
guido7834
How much wobble are you talking about? Mine has just the very slightest at idle, none at increased rpms.
Old Feb 11, 2011 | 07:04 AM
  #34
ipuig's Avatar
ipuig
St. Jude Donor '09
Good luck.
I'd like to hear more about this method.
Old Feb 12, 2011 | 01:19 AM
  #35
ChromeC5's Avatar
ChromeC5
Great Advice Cratecruncher. I have an ATI balancer waiting for my car to come out of storage. I will also be on the search for the tool you mention (I assume you sold yours?).
If heat is needed, I'm probably only going to do it to get the old balancer off. I purchased a longer bolt for installing the new balancer then I plan on installing the GM bolt for the final installation and torquing.
Old Feb 12, 2011 | 12:47 PM
  #36
Cratecruncher
Chrome,
I haven't sold my flywheel lock yet and it's for sale. Just send me a PM. Also, the safest way to install the new Balancer is with an installation tool. I made mine from a piece of M16-2x300 threaded rod and some nuts based on good advice on this forum. I have some extra rod I'll throw in with the J-tool because it only comes in 4 foot lengths and I now have a lifetimes worth. You can still use your longer bolt as a push point for your puller - it works better than a socket in my opinion. I drilled a small dimple in the center to prevent the puller from wandering.
Old Feb 12, 2011 | 01:21 PM
  #37
MawneeC5's Avatar
MawneeC5
Yea, you dont have to completely remove the rack, just unbolt it and get it hanging out the passenger side so its out of your way. I did it that way to pin my crank on my 98. It takes some wrestling, you have to rotate it a bunch of different directions to get it through. When I did my cam swap on my Z06 I just pulled it all the way out(since everything was out of the way anyway
Its not too bad a job, just time consuming. The hardest part is the crank bolt itself. I personally use a jack handle(about 4ft long) slid over my 1/2" break bar. Plenty of leverage
Old Feb 12, 2011 | 03:06 PM
  #38
81c3's Avatar
81c3
A good impact wrench is the best way to remove the balancer bolt, hands down! Took me like 3 minutes and it was out.
