Help with Remounting Right Side Front Spoiler
Old Dec 31, 2006 | 12:39 PM
Michael A's Avatar
Michael A
Default Help with Remounting Right Side Front Spoiler
Apparently I hit something harder than usual on the right side with the front spoiler, although not hard enough for me to even remember hitting anything. The right side spoiler is bolted directly to C-clips which clamp onto the front facia. I've got to say, this is a "horse's @ss" design, because what's happened is the C-clips are tearing through the flexible front facia material, and now the spoiler is falling down. The rubbery facia material has no strength at all for mounting something like this. I don't know how they expected this to last over time. At least the front center section is done right, and is spring loaded.
Anyway, I know we have a lot of creative people on this forum, so I am looking for ideas on how to remount the right side spoiler given the front facia is torn at each C-clip. I'm afraid if I just use metal washers they will tear through the front facia making even bigger holes. It is almost like I need something semi-flexible that won't cut through the facia. Let me know what you guys have done (I'm sure I am not the first with this problem).
Michael
Old Dec 31, 2006 | 05:59 PM
Bill Dearborn's Avatar
Bill Dearborn
I had an incident at an autocross with my 97 where I tore the spoiler off the car. The fascia was torn in multiple spots where the C clips fastened. I cut a piece of sheet metal to fit above the fascia and strengthen it at each one of the holes. Sort of like a rectangular washer.
Bill
Old Dec 31, 2006 | 06:18 PM
hotwheels57's Avatar
hotwheels57
How about some 1/8" ABS plastic after fabbing with a pattern with cardboard first? It's pretty rigid, but still forgiving to impact and you could even use SAE "nut serts" (basically threaded rivets) to mount the air damn into the plastic.
Old Dec 31, 2006 | 09:12 PM
BlackZ06's Avatar
BlackZ06
Originally Posted by Michael A
.... I've got to say, this is a "horse's @ss" design, because what's happened is the C-clips are tearing through the flexible front facia material, and now the spoiler is falling down. The rubbery facia material has no strength at all for mounting something like this. I don't know how they expected this to last over time. At least the front center section is done right, and is spring loaded. ....
Michael
Michael,
I believe Chevy designing it this way was actually a smart move. If they'd designed it so that a large force striking the air dam didn't easily tear off the dam itself (which is what yours did), then damage would occur to the fascia itself, which would be MUCH more expensive to replace.
The GM part number for the right front spoiler is:
10419313
Look it up on various vendor sites and you'll see the dam only costs about 8 bucks. MUCH cheaper to just replace it rather than having the fascia itself damaged.
HTH
Old Dec 31, 2006 | 10:28 PM
jwg2's Avatar
jwg2
Originally Posted by BlackZ06
Michael,
10419313
HTH
heh, I have to disagree with you. I actually have the same problem...and it is a dumb design because it *is* damaging the facia. mine ripped all three nuts right through the facia leaving three half moon holes in the body work. the facia was certainly still snuggly fastened to the spoiler lying on the other side of the gator!. I was looking at solution similar to the one suggested further up the thread; fashioning a piece of metal in the shape of the facia and riveting it in, then attaching the spoiler to the new metal piece. Ecklers also sells a reinforcement piece for those of you who haven't lost your spoilers yet.
http://www.ecklers.com/product.asp?p...dept%5Fid=1460
Old Dec 31, 2006 | 11:08 PM
TEXHAWK0's Avatar
TEXHAWK0
If you don't want the holes to tear out, cut a curved strip of heavy gage metal to match the top of the spoiler, drill holes to match the spoiler, and bolt it on using the metal as a backing plate.
That ties all the holes together the length of the spoiler.
Of course, if you ever hit anything, it will probably rip the whole nose of the car off!
Old Jan 1, 2007 | 09:58 AM
jwg2's Avatar
jwg2
yea, no kidding. it would have made sense to design it the way blackz06 described.
Old Jan 2, 2007 | 04:06 PM
Michael A's Avatar
Michael A
Michael,
10419313
HTH
HTH,
I think you misunderstood my description. It DID damage the facia The spoiler is stronger than the facia, and the C-clips just ripped right through the facia material. The spoiler looks fine, and I don't even see where it hit. I wish they had designed it so the spoiler would "tear away" as you stated, and leave the facia intact.
Michael
To Help with Remounting Right Side Front Spoiler
