Question about: ARP MAIN STUDS
Old Jan 2, 2007 | 01:06 PM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Question about: ARP MAIN STUDS
I purchased a short block with ARP main studs installed...I was going to put my windage tray on and noticed the studs were a lot bigger than the nuts. Does the ARP main stud kit come with the windage tray nuts or are they a special order item or can I use a standard nut from an automovtive shop (if so, what size?) ?
Old Jan 2, 2007 | 01:11 PM
kromberg's Avatar
kromberg
The ARP main stud kit I bought worked perfectly fine with the windage tray. Washers and nuts should be part of the stud kit. If you did not get them, raise hell with the person you bought the short block from. If worst comes to worst, they can be order directly from ARP.
Keith
Old Jan 2, 2007 | 01:14 PM
2004SpiralGrey
Keith
thanks
To Question about: ARP MAIN STUDS
