Radar detector question
Old Jan 2, 2007 | 09:59 PM
harleycontracter's Avatar
harleycontracter
Default Radar detector question
Will radar detector work properly through the shaded part of the windshield?
Old Jan 2, 2007 | 10:01 PM
LoneStarFRC's Avatar
LoneStarFRC
Radar? Yes.
Laser? No.
Old Jan 2, 2007 | 10:06 PM
Rob Petyo's Avatar
Rob Petyo
Originally Posted by LoneStarFRC
Radar? Yes.
Laser? No.
Mine is mounted to the rear-view and it picks up laser too.
Old Jan 2, 2007 | 10:14 PM
LoneStarFRC
It may be possible for some laser to penetrate the tint, but your detection range range will be greatly reduced. In order to have the most effective use of your laser detection, it needs as clear a glass as possible.
I have my detector mounted to my rear view mirror also. It is mounted in such a manner that it "looks" out the windshield through the clear portion of the glass, not the tint. Main reason for that is I wanted it to have an unobstructed look out the rear window too. (Using Valentine1)
Laser detection is pretty much of a moot point anyway as far as I'm concerned. I rely on my detector for radar and radar only. For laser use I have had excellent results with an Escort Laser Shifter. It has "helped" me on three different occasions.
Old Jan 2, 2007 | 10:23 PM
Rob Petyo's Avatar
Rob Petyo
good to know!
I also have 15% tint on the sides and rear and it picked it up a few times.
I rely on it mostly for radar too (escort 8500) I figure if I'm doing something wrong and got hit with the laser, it was too late anyway.
Old Jan 3, 2007 | 04:54 PM
FASST LN's Avatar
FASST LN
I thought the HUD windshields in our car greatly reduced the effectiveness of a radar detector. I believe I read that in a magazine somewhere.
Old Jan 3, 2007 | 05:41 PM
VetteDrmr's Avatar
VetteDrmr
Not mine. Bel 980 works just fine, sitting on the corner of the dash pad left of the HUD.
Have a good one,
Mike
Old Jan 3, 2007 | 06:38 PM
LoneStarFRC
good to know!
Not necessarily so. Take a look at Escort's Laser Shifter or the Blinder line of products. With them, you have a fighting chance against laser. As I indicated, my Laser Shifter has proven effective on 3 separate occasions for me.
Old Jan 3, 2007 | 07:26 PM
hisvett's Avatar
hisvett
St. Jude Donor '14-'15
Default Tent Test
This is a test you can do to check out your window film; use your garage door opener....find max distance you can open your door while shooting through the window film in question, then move just beyond that point so the door will not open(note distance). Then move the opener outside of the window film and retest. If the distance is the same....you are good to go, if not, you are loosing signal through the film.
(this test was told to me by the Val 1 people several years ago when I purchased my detector)
Old Jan 3, 2007 | 09:57 PM
ALLEGRO's Avatar
ALLEGRO
Old Jan 3, 2007 | 10:25 PM
mark896's Avatar
mark896
http://forums.corvetteforum.com/show....php?t=1545251
Old Jan 4, 2007 | 09:22 PM
LoneStarFRC
Unless this is done with a "laser" garage door opener, this "test" is invalid. Garage door openers that I'm aware of use radio frequency waves, not laser. Window tint is invisible to RF.
Old Jan 5, 2007 | 09:04 PM
hisvett's Avatar
hisvett
Correction ........If the window tent is of a metal reflective type , it will most definitely have an effect on RF Waves (Radar, Garage door openers, ect.). This is why the test, as stated before, will determine if metal is present in the window film .
To Radar detector question
