Problem Programing Key Fob, Help
Old Jan 3, 2007 | 08:19 PM
Corvette Don's Avatar
Corvette Don
Default Problem Programing Key Fob, Help
I got the fob in today. My car when I got it last week did not have one, I do have a Canada Spec car. Well I followed all the instructions on programing and even re-syncing the fob, it works good up untill I start the car then after that it wont work till I do one of the above again. It does have a fresh battery (in the fob), any idea what could be wrong??
Edit I do have a 00 coupe and the fob # is AB00216T
Old Jan 3, 2007 | 10:02 PM
Corvette Don
I know this has had to happen to someone
Old Jan 4, 2007 | 08:03 AM
bluvette79's Avatar
bluvette79
if you are lucky, it could be that the battery is a little loose. check the contacts (in the fob) and bend a little to make sure there is good contact. other than that......, good luck!
have you tried a key fob search on this forum?
jim
Old Jan 4, 2007 | 10:12 AM
Corvette Don
jim
Yes I tried to search, its not the battery cause it will re sync/re program just fine and work fine untill i start the car, then it wont work again till i re sync it again
Old Jan 4, 2007 | 12:08 PM
gpracer1's Avatar
gpracer1
If the fob is used, then you probably need a new one. They just go bad. Did you get it used on ebay or is it brand new?
To Problem Programing Key Fob, Help
