During a DIC code scan I notice a LOW BATTERY VOLTAGE code. Are there operating limits/specs on the 12V? I measured the voltage (at the battery terminals) with a precision DMM in three different states:
1.) Vehicle running - 14.12V
2.) Vehicle off/key on - 12.36V
3.) Key off - 12.11V
Are these numbers within spec? Thank you for any insight you guys can provide.
Easily within specs, what does the DIC read when key on and motor not running? Is the code a history code? Mine drops down to a little below 11 volts when I don't drive it for a while, but I get no codes. Still starts and reads 14.2 when running. The DIC may read different from a voltmeter at the battery.
