Thermostat problems
Old Jan 5, 2007 | 12:18 PM
Scotty3's Avatar
Scotty3
Default Thermostat problems
What temperature would you expect to run with a 170 deg. thermostat?
I am running warmer with a 170 deg. thermostat than I was with the 180 deg. thermostat I took out. I followed the GM procedure for bleeding air but my highway cruising temperature went up instead of down. My fans are set to come on at 195 deg. and my highway temperature is up to 203 deg., before it was hanging right at 196 deg. I was trying to keep my fans from running all of the time.
Any suggestions?
Old Jan 5, 2007 | 03:02 PM
BATM4N's Avatar
BATM4N
190-200 degrees is the sweet spot so not sure why you would want to run cooler than the 196 degrees you were getting with the stock 190 thermostat.
By your thread, you make it sound like your fans were coming on while you were on the freeway and reading 196 degrees. The wind would actually be keeping the fans from coming on since they won't kick on until 130 degrees or so depending on the year of your Vette.
Now that you have the fans set at coming on at 196 degrees, that is awfully low for an LS1 engine and now your fans are coming on all the time, which is what you said you didn't want to do.
If you want to run your engine cooler than 190-200 degrees, best way is to get a bigger radiator with your 170 degree thermostat.
Old Jan 5, 2007 | 04:53 PM
robvuk's Avatar
robvuk
Old Jan 5, 2007 | 05:24 PM
6Speeder's Avatar
6Speeder
If your temps went up and you made no other changes, then that thermostat probably isn't working right. I have seen some vendors modify GM stats to make them open at lower temps and screw them up. Maybe yours isn't opening fully or not at the right temp. Test them in a pot of water as it heats they should open. Remember, a 180 thermostat just starts to open at 180 and the vehicle will usually run above that point. The Hypertech thermostats seem to be reliable and open when advertised. I run their 160 thermostat and my highway speed temps hover around 175 when it's cold, 180 in the summer. Just right.
Old Jan 5, 2007 | 05:28 PM
FKING1's Avatar
FKING1
No suggestion , but, my 178 runs at 183 on the highway and 195 or so in traffic. My fans are set at 190.
Fred
Old Jan 5, 2007 | 07:31 PM
Vette#2's Avatar
Vette#2
My 172 stat didn't do a thing for me even with the fans reset. Another $ wasted. Just my 2 cents
Old Jan 6, 2007 | 09:23 AM
98blackonblack's Avatar
98blackonblack
How are yall resetting the fans?
Old Jan 6, 2007 | 09:26 AM
6Speeder's Avatar
6Speeder
tune. I used LS1 Edit. Other, newer, programs out there.
Old Jan 6, 2007 | 10:18 AM
oldschoolvette's Avatar
oldschoolvette
something doesnt make sense. I have put lower temp stats in several cars and reset fans and the cars run 180 on highway and about 196 in traffic. I would look at the stat being bad if the fans are really set correctly. my .02
Old Jan 6, 2007 | 05:32 PM
cjs27410's Avatar
cjs27410
The fans disable above 35 MPH whatever the temps are.
Old Jan 6, 2007 | 06:07 PM
Thickraybans's Avatar
Thickraybans
Default Thermostat
I have a 160stat & run around 180-190. You may have sucked some junk up off the road and blocked the radiator. Mine likes collecting all kinds of trash.
Old Jan 8, 2007 | 08:05 PM
BATM4N's Avatar
BATM4N
Thanatos is correct. I forgot to look where your located and since your in Virginia there is a good chance you have leaves, walmart bag, or some other foreign object caught up in your radiator. These things are vacuum cleaners of foreign debri
To Thermostat problems
