Speed / Stability
Old Jan 5, 2007 | 08:31 PM
frank dupuy's Avatar
frank dupuy
Default Speed / Stability
Does anyone have experience or knowledge on the maximum stable straight line speed for a C5 Vert running with the top down? Let's assume this is on a straight line closed course. Also let's assume the car has unlimited HP and all mechanicals / tires are high speed capable. We know the C5 coupe is the best aerodynamic design of the three models and capable of safe speeds of 200 MPH. So would the C5 topless design exclude it from the 200 MPH club?
Old Jan 5, 2007 | 09:10 PM
tiojames's Avatar
tiojames
Your post says unlimited horsepower, so, yes you could achieve 200 if the car could stay straight. I think the turbulence would be such that I wouldn't want to be driving it. I ran my 56 vette at Murdock a long time ago with the top off and a full tonneau cover and it ran 172 with 620 HP. I ran out of gears. That was in 1958.
Old Jan 5, 2007 | 09:26 PM
Rag-Top Rick's Avatar
Rag-Top Rick
Assume?
Kinda sounds like a car owned by someone we all know!
That being said, we can assume that a person driving a " a Supercharged/Topless C5" at the speeds noted above " AIN`T RIGHT!"
Anything above 110mph the buffeting will beat the crap out of you...... on a closed course mind you!
c4cruiser's Avatar
c4cruiser
Given unlimited HP, the car could be capable of some very high speeds. You could build a motor that would crank out 1000HP and the car might do 250 or more. Brute force in terms of HP and torque will push the car to high speeds but it's possible that aerodynamic drag with no top may make the car unstable or even dangerous ast extreme speeds.
I would think that even if you could stand the turbulance inside the car, it could hit 200 assuming the car had the necessary HP. It would probably take less HP if the top was up or if you used a coupe. There would have to be a fair amount of drag due to the loss of the top surface for airflow over the car.
I had read an article about the C6 Z06 where it was mentioned that it can hit 200MPH with the stock motor IF you remove the outside mirrors. Otherwise, the car would only do 195 or so. So if that small amout of drag makes a few MPH difference with the same motor, you may need a considerable increase in HP to get a top-down vert to hit 200 compared to the top being up or a coupe body.
Old Jan 5, 2007 | 10:01 PM
Dirty Howie's Avatar
Dirty Howie
Lets also assume you are ducking down so your BIG FAT HEAD isn't sticking up in the air stream
DH
Old Jan 5, 2007 | 10:15 PM
BlackZ06's Avatar
BlackZ06
Given unlimited HP .... well the theoretical top speed would be limited to your engine redline in top gear .... and to figure out that top speed ...
Put the car in top gear (6th) and cruise at say 2000 RPM. If your speed is 80 MPH at 2000 RPM and your red line is 6000 RPM, then your top speed would be 3 times faster than your current speed (3 times 2000 = 6000 .... so 3 times 80 = 240 MPH!!!)
Whether the mirrors would rip off ... the front end lifts ... well ... LET US KNOW !!!
Old Jan 5, 2007 | 10:26 PM
frank dupuy
DH
Howie! I knew you would come forward with some smart az answer. The very thought of my C5 Vert and my big head flying past you on your next Hard Core Run must be keeping you awake at night.
Old Jan 5, 2007 | 10:32 PM
gpracer1's Avatar
gpracer1
I know that headlights up makes about 5mph difference from 176 on and lights off 181.
Old Jan 5, 2007 | 10:40 PM
frank dupuy
Originally Posted by R.P.
Assume?
Just a few know me and they are probably convienced by now I ain't right. but I do Know 170 MPH with top down is one stimulating ride. But what I need to know is what comes after 170 mph.
Old Jan 5, 2007 | 10:49 PM
Burgie's Avatar
Burgie
You wouldn't be able to hear it but if you look in the mirror there would be flashing lights,,,,,,,way back there
Old Jan 6, 2007 | 12:49 AM
frank dupuy
Don't think I haven't thought about that. And that is one of many good reason to use a closed course rather than exceed the posted speed limit on public roads.
To Speed / Stability
