100,000 mile info please
Myself, I would check over the car and go over nuts bolts etc, all fluids, belts, hoses, lube what is necessary and drive it for another 100K.
Change Oil & Filter Lubricate chassis
Inspect exhaust system Inspect all fluid levels
Inspect brake system Inspect & adjust drive belts
Check electrical system Inspect cooling system
Inspect & service battery Inspect tire system
Balance tires Replace air filter
Inspect & adjust clutch Inspect fuel vapor storage sys
Tighten nuts/bolts on chassis Replace PCV valve and filter
Replace fuel filter Change Coolant
Change transmission fluid Flush brake system
Replace spark plugs
VETSTYL
