Memory seat function malfunction?
Old Sep 30, 2001 | 08:44 PM
gaww's Avatar
gaww
Default Memory seat function malfunction?
Even though I have my "easy exit" feature off on the DIC, everytime I enter my car, the seat moves all the way back. Not a big deal since I push the memory feature and my seat moves back to my preferred position. However, sometimes when I press the memory button, it seems the car doesnt know what the preset was and I have to manually readjust my seat. Anybody know what's wrong? Minor detail but it gets annoying after a while. Thanks
:flag
Old Sep 30, 2001 | 10:56 PM
mikecoffin1's Avatar
mikecoffin1
Default Re: Memory seat function malfunction? (gaww)
I just had mine corrected for that and other problems last week. About 50% of the time, the seat would not return from the exit position when I inserted the key OR pressed either memory button. It was fixed under warranty. The info from my dealer work order lists the following:
Cause: internal failure
N4924 module, local interface unit
9360841 module
Part #: 9360841
Mine is a '99 convert. Hope this helps you. BTW, the problem started as intermittent and over about a three month period, worked up to about 50% inoperative. Mileage was 28,000, only one driver, and setting left in the automatic entry/exit mode. :seeya
Old Oct 1, 2001 | 12:09 AM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Memory seat function malfunction? (mikecoffin1)
Same thing happened to my '99 vert.
Old Oct 1, 2001 | 02:13 AM
Roofless's Avatar
Roofless
St. Jude Donor '11,'13
Don't ask me whjy, but try to remove your key a little slower, for some reason that seems to work well. :confused:
To Memory seat function malfunction?
