Tire experts please step in...
Old Jan 6, 2007 | 01:58 PM
acerider's Avatar
acerider
Default Tire experts please step in...
Is there potentially a problem with going with a lower load index when switching tires? More specifically, is going from a 99 index to a 94 index tire okay for a non-raced, non-tracked daily driver? The load index for a 99 is 1709 lbs. vs. 1477 for the 94. My thought is that, because the GAWR on my '98 coupe is shown as 1977 lbs., each individual rear tire is under a load of 988.5 lbs. (1977 divided by 2). Putting tires with a 94 load index (again, 1477 lbs.) theoretically, would mean that each individual tire still has 488.5 lbs. (1477- 988.5) of unused "load room" vs. 720.5 lbs. with the 99 index tire before it experiences failure.
I don't see any obvious problem here, but then I'm not a tire guy either. Any input would be most appreciated. Thanks.
Old Jan 6, 2007 | 02:11 PM
B-ras's Avatar
B-ras
You're fine. I haven't seen a tire in C5 sizes that has a load index low enough to be a problem, but anything in the 90+ range is sufficient.
Old Jan 6, 2007 | 03:12 PM
R Devil's Avatar
R Devil
I don't see any issue other than why would you do it??
Old Jan 6, 2007 | 06:56 PM
BlackZ06's Avatar
BlackZ06
Remember that the weight rating does not take into account what happens when the vehicle is moving. Hard acceleration moves much of the cars weight to the rear tires, while braking moves most of the cars weight to the front tires. Same thing with cornering, the outside tires in a corner carry much more of the vehicles weight than the inside tires.
However, the Eagle F1 Supercar tires on my Z06 have a load rating of 91, so I'd think you're gonna be OK with a 94
Old Jan 6, 2007 | 08:41 PM
acerider's Avatar
acerider
Long story short, Falken doesn't make 19" tire that fits an 11" wheel very well, other than the new FK 452 315/25, which is load indexed at 94.
Thank for the input guys!
To Tire experts please step in...
