Help please with a plug connector post header install
Old Jan 7, 2007 | 04:34 AM
fej's Avatar
fej
Default Help please with a plug connector post header install
OK. Spent several hours (ok way too damn long) doing my AR header install today. After what I felt were some difficulties getting them mounted (bam! .. not so much) I got everything routed well, fit and finish are solid, everything looks good. Well except this one connector which for the life of me I cannot find a home for.
The connector has a purple trim ring and is what I would call 3 prong. This is NOT an oxygen bung connector as those are both connected and zip tied up and out of the way. It is on the passenger side inner fender area and looks like it should be connected up closer to the header flange rather than down by the collector.
Please help it was dark and I do not have pics at this point. Will be hitting up the manuals in a few minutes. Thanks in advance
Oh btw, the car would not start. Guessing it is this connector as everything else is connected (coil packs, o2 bungs etc etc)
Fej
Old Jan 7, 2007 | 04:38 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Off the top of my head I would suggest trying to find a home for it on the starter?????
Old Jan 7, 2007 | 06:24 AM
hip's Avatar
hip
It's the distributor wire
Old Jan 7, 2007 | 07:53 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If you find a distributor on your C5 please post a picture.
This connector either goes to the crank position sensor or the oil level sensor, I didn't have to disconnect either of these to install my headers but you may have for some reason.
The crank position sensor is above the starter and the oil level sensor is in the side of the oil pan, both on the passenger side of the car.
Old Jan 7, 2007 | 09:52 AM
Patches's Avatar
Patches
Crank position sensor is #1 in this illustration.
Oil level sensor is lower and nearby.
Ignore my WB O2 sensor - the oil level sensor plug is blue here.
Old Jan 7, 2007 | 10:43 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Patches >> once again, a wealth of knowledge with great pics
Old Jan 7, 2007 | 01:33 PM
fej's Avatar
fej
Wow Patches thanks a ton, that must be exactly the problem and based on how the wire was curved must be the connector I am missing (and the reason the car won't start). Great diagram as well.
Thanks to all that responded I will be headed over to my buddies shop in a bit to see if I can get it worked out.
Fej
Old Jan 7, 2007 | 05:07 PM
DPG's Avatar
DPG
St. Jude Donor '06
Fej
The man who can wire up a stereo in a matter of minutes can't connect a harness to a connector just messin with ya. hope you love the new headers. I love mine
Old Jan 7, 2007 | 07:15 PM
fej's Avatar
fej
Connector issue solved, if my arms/hands were 1/2" thicker I would have had to pull the header and the starter, took me 20 minutes to get it connected and locked into place.
Have other issues that I need to check out but the headers are all squared away I think. Thanks again
Fej
To Help please with a plug connector post header install
