cleaning radiator..
Old Jan 7, 2007 | 12:34 PM
dwarmenzerk's Avatar
dwarmenzerk
Default cleaning radiator..
can i just take a pressure washer and shoot it thru the back of it and allow that to blow all the crap out?
Old Jan 7, 2007 | 12:42 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
When i had mine out when i did my cam swap i used shop air and blew it out. Im not sure about the pressure washer....someone else may be able to shime in
Old Jan 7, 2007 | 12:54 PM
dwarmenzerk
yeah thats what ive been doing with the air pressure, just i have a pressure washer that i can use and was thinking about doing that!!
Old Jan 7, 2007 | 01:24 PM
rws.1's Avatar
rws.1
air compressor or pressure washer both work...
Old Jan 7, 2007 | 02:43 PM
hotwheels57's Avatar
hotwheels57
The fins on an aluminum radiator are fragile...and an aluminum radiator uses additional fins in the design to cool so they're very thin. They're not straight like a copper brass radiator. Just be be very careful in using anything powerful like a pressure washer or even air pressure against the fins. They're almost impossible to straighten if they're bent and you can't use a "radiator comb" to straighten them.
Old Jan 7, 2007 | 10:36 PM
dwarmenzerk
hmm.. whats this 'radiator comb'
Old Jan 8, 2007 | 01:13 AM
jjvet's Avatar
jjvet
I used blow end of vacum cleaner
Old Jan 8, 2007 | 12:15 PM
hotwheels57
A radiator comb is/was used on old technology copper brass radiators with straight vertical cooling fins. It's used to straighten damaged fins to improve the air flow. The tool has different toothed sections depending on the width of the fins. When aluminum radiators became standard, the fins increased in count with a different angled pattern, which doesn't allow the use of the tool.
To cleaning radiator..
