Passenger Power Window won't work
Old Jan 7, 2007 | 09:22 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Default Passenger Power Window won't work
I have a 98 A4. Seems everthing has been acting up lately. This week the Passenger Power Window won't work. I searched the forum for old posts about this but could not find it. What is the typical fix for this?
Old Jan 7, 2007 | 09:38 PM
cruisemon's Avatar
cruisemon
Search electrical issues, and tech issues, using keyword power window. There are dozens of posts on temporary fixes and permanent fixes. After you try the door slamming while holding the switch down, etc., buy a regulator or at least the motor, replace the defective one and be done with it.
Charlie
Old Jan 7, 2007 | 09:54 PM
Dustie's Avatar
Dustie
I bought a new regulator assembly and installed it myself, not particularly hard to do...
Here's how to get the door panel off...
http://www.vetteessentials.com/instr...or_handle.html
Old Jan 7, 2007 | 09:57 PM
Darkness's Avatar
Darkness
Just tap hard on the inside of the door. It happened to me a couple of times already. Its the motor gears that get stuck. Just hit the panel and click the button at the same time and it will work. No need to replace anything.
Old Jan 7, 2007 | 10:56 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
call Chris, happened to his car during the PRI show, the connector often fails in the accordian
cajundude had this happen recently
Old Jan 8, 2007 | 08:36 AM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Go figure - today it works
Old Jan 8, 2007 | 09:19 AM
CMYC4GO's Avatar
CMYC4GO
Sounds like you have a faulty connection, making intermittent contact.
To Passenger Power Window won't work
