HVAC Control Module Display...Cant See!!!
Old Jan 8, 2007 | 11:06 AM
aquachuck1's Avatar
aquachuck1
Default HVAC Control Module Display...Cant See!!!
HVAC Control Module Display has been getting dimmer and dimmer....today I cant see it at all....although all functions work.
Can the "display" part of the module be checked out and be repaired or as my GM Dealer tells me I must replace the complete module at a cost of $421.00.
Any help would be appreciated.
Old Jan 8, 2007 | 11:17 AM
cliff_ford's Avatar
cliff_ford
If you do a search you will find a lot of information about soldering some resistors. I followed the instructions and fixed mine in about half an hour.
Old Jan 8, 2007 | 11:55 AM
aquachuck1's Avatar
aquachuck1
Default HVAC Display
Thanks....found plenty of information and it seems very do-able....have to get to Radio Shack for one of those cold solderer.
Old Jan 8, 2007 | 12:14 PM
cliff_ford's Avatar
cliff_ford
I would buy a cheap solding iron and standard solder if I were you.
Old Jan 8, 2007 | 12:51 PM
Mongolink's Avatar
Mongolink
Default very easy fix!!!
Did mine a few months back. take yer time and relax be careful when you do the ones that are loose they will slide when you resolder them.
I agree with cliff_ford Radio Shak and some fine electonic solder a small pencil tip soldering iron and your all set
Use the $400.00 ya save on some cool new mods!!!
good luck
Tom
Old Jan 8, 2007 | 01:04 PM
rws.1's Avatar
rws.1
If you are concerned about doing it yourself...
CF member mandigital
e-mail digitalguy_1@charter.net will do it for under $50 with return shipping complete with a 5 year guarnatee...
To HVAC Control Module Display...Cant See!!!
