popping when turning
Old Jan 8, 2007 | 06:44 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default popping when turning
Ok... So about a month ago i started to notice a popping sound/viberation when i turn either direction. I can't find the source of the problem.
I can say that the powering steering fluid was over filled.. ya i know... and not just a little.. I'm not sure how screwed that up but some how i did... lets assume for a min that it's because of my fuild being over filled. What kinda damage would i have caused... I wish i could say this was someone else's fault but i know better... I f'd up...
Old Jan 8, 2007 | 07:15 PM
N0TDADYS_98
btw turning is free and easy... so power steering deff works but as you turn you can mostly feel/hear the popping... it pops the more you turn it out... not louder popping just more of it...
example zig zaging within say a lane might yeild 1 pop both ways... a full turn might yield 3 pops both ways.
Old Jan 8, 2007 | 07:47 PM
N0TDADYS_98
just jacked the car up in the air and let the tires hang free... got in and turned the wheels no popping... so what is different about turning wheel with the wheels free vs when on the ground???? the obvious comes to mind but i can't think of how this helps me if at all figure out what is wrong.. btw car was no running for this test...
Old Jan 9, 2007 | 08:53 AM
3rd Childhood's Avatar
3rd Childhood
Wheel bearings maybe? I had that happen once in the old days.
Old Jan 9, 2007 | 09:32 AM
N0TDADYS_98
wouldn't that usually equal viberation the faster you go?
Old Jan 9, 2007 | 09:55 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Sounds as if when under load you have the popping. It could be the ball joints or the end links dry. Have someone turn the wheel while it is on the ground while you can examine it!
Just be sure if the car is on that the individual will "NOT" put it in drive while you're under the front doing the visual inspection. You also might try holding on to the rack to feel where the popping is coming from!
Let us know what you find! Two man job at this point.
Thanks,Matt
Old Jan 9, 2007 | 10:38 AM
Architect's Avatar
Architect
It sounds like your sway bar end links need greased or replaced. Definitely doesn't sound like a steering pump or wheel bearing issue.
Old Jan 9, 2007 | 10:40 AM
Smoove
Guest
Posts: n/a
Thanks,Matt
Werd.
It's either a tie rod end link binding...or ball joint...etc.
Check for wear in these area's. Sometimes noises like this can be duplicated when going over speed bumps slowly, and turning the wheel.
Also, when at full lock, go in reverse, and slowly back up. If it is any of the above stated ideas or possabilities...you'll hear it then.
Old Jan 9, 2007 | 11:54 AM
JCrouse's Avatar
JCrouse
Mine started the same thing about a week ago. It only does it in drive, and only within the first 5-10 minutes of starting the car, and only at low speed (ie in the parking garage). Strange.
Old Jan 9, 2007 | 02:00 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
What kind of grease can be used?
Old Feb 19, 2007 | 11:03 AM
N0TDADYS_98
Replacin endlinks today... will post back.
Old Feb 19, 2007 | 11:24 AM
DPG's Avatar
DPG
St. Jude Donor '06
Old Feb 19, 2007 | 11:30 AM
DanielZ06's Avatar
DanielZ06
Originally Posted by DPG
Also interested to see outcome...
Old Feb 19, 2007 | 07:36 PM
N0TDADYS_98
big improvment. but i can still feel it.. i'm wondering if i'm paying to much attention to the feel of my steering.. I guess seeing as there is a huge improvement... I'm thinking it might be my bushings... I greased them up real good with some WD-40... I'm wondering if they are binding..
Suggestions for bushing??? Difference between Coupe and Z06 bushing?
Old Feb 19, 2007 | 08:11 PM
DPG's Avatar
DPG
St. Jude Donor '06
could it be the shock bushings. I know that in my old camaro i had to change a strut mount when i had this same feel that you are talking about. I wonder if there is soemthing similar, i know there arent any struts, but something like it
Old Feb 19, 2007 | 11:22 PM
N0TDADYS_98
it comes and goes... i'm going to get some new rubber bushing from my local dealer this week and give that a try..
Old Feb 19, 2007 | 11:58 PM
BATM4N's Avatar
BATM4N
To popping when turning
Old Feb 20, 2007 | 12:16 AM
BarneyZ's Avatar
BarneyZ
Have you changed the sway bars? Mine caused popping on turns when not torqued properly. Thought sure it was an exhaust system problem. D*mned near drove me nuts!
B
Old Feb 22, 2007 | 10:19 AM
N0TDADYS_98
What are the correct Tq specs for the front sway bar bushings?
Old Feb 23, 2007 | 12:09 PM
N0TDADYS_98
TTT
lubing those bushing is helping but not perfect..
