Those with Texas speed and performance headers
Old Jan 8, 2007 | 06:48 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Those with Texas speed and performance headers
Ok... so question... After installing my headers my O2's touched them and shorted out.. It's been this way for awhile and i'm tired of that darn check engine light. So i have 2 new o2's ready to go in.. I should have asked this question 6 months ago but it didn't bother me at the time...
There are little tabs on the headers that bolt up to the fram of the car right behind the oil pan. Mine dont' even come close to touching (being able to bolt up)... are there different versions of headers based off year? did i get a bad set? or is this pretty normal????
Also one of my 02's rub against my tunnel plate is this bad???? when i say rub i mean slightly pressed against.
Old Jan 8, 2007 | 07:49 PM
c5mtl's Avatar
c5mtl
Default tabs
i got mine last year and the tabs dont even come close to lining up.....dont even know why they r there
my car is an a4 maybe they are there for manual cars
Old Jan 8, 2007 | 07:52 PM
N0TDADYS_98
nope... i'm running an M6.... hmmm i wonder if TSP is aware of this? i'm sure someone has called at somepoint to btch
how do you O2's fit???
Old Jan 8, 2007 | 08:51 PM
108C6's Avatar
108C6
my lg lts left did not line up did not like much to line up called lg they told me to py it ovev and bolt it up it worked i know their tsps but try this
Old Jan 8, 2007 | 09:02 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Tabs don't line up, its a manufacturing thing. If your O2 "shorted" out electrically, theres a bad problem somewhere. I'd get the electrical fixed before anything else.
Old Jan 9, 2007 | 11:35 AM
Uncle John's Avatar
Uncle John
Will they line up if you rotate the frame bracket 180 degrees?
Old Jan 9, 2007 | 10:55 PM
dazman's Avatar
dazman
there is no such thing as an aftermarket product that you will not have to afro-engineer on.
To Those with Texas speed and performance headers
