are LS1/LS6 rockers same as LS2
Old Jan 9, 2007 | 08:35 AM
patriot's Avatar
patriot
Default are LS1/LS6 rockers same as LS2
Does anyone know if the stock rocker arm GM used in the LS2 is the same as those in the LS1/LS6? Thx.
Old Jan 9, 2007 | 02:03 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
No I beleive they are different but similiar to new C6 ZO6 one's.
Old Jan 9, 2007 | 06:42 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default C5 Z06 & LS2 = 243 heads
I would think that since they both use the same heads that the rockers should interchange.
The only difference between them is the sodium filled exhaust valves in the Z06 heads.
Bob K.
Old Jan 9, 2007 | 08:27 PM
patriot's Avatar
patriot
Thanks for the replies. Bob, you are correct. I talked to a few builders today and the rockers are interchangeable.
Old Jan 9, 2007 | 11:59 PM
rhneff's Avatar
rhneff
While the LS2 rockers can probably be interchanged with the LS1/LS6, IIRC the LS7 rockers are completely different and unique to the LS7 and cannot be used in the other applications.
Old Jan 10, 2007 | 08:06 AM
Casem1's Avatar
Casem1
Maybe you should say "are not recommended to be used in other applications"
There are guys on here that are running them in their LSx engines. I was following this topic for a while. They got a bad wipe pattern but I don't recall and catostrophic failures. Last I knew, someone was well over 10k miles with them with no unusual valve tip wear.
Old Jan 10, 2007 | 08:11 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Rocker arms are attached to the heads of an engine, when you say people are using them on there LSX engines thats just saying someone bought an LSX block and built a motor, heck they probably put LS7 heads on it.
The reason the LS7 rocker arms cannot be used on an LS!,2 or 6 head is because of the shape of the intake port and location of the pushrods caused the intake rocker arm to be offset.
To are LS1/LS6 rockers same as LS2
