AARP Special (2001 Z06)
Lomotion Corvette (poughkeepsie,new York) Flowmaster,blackwing Intake. Great Job
512 Horse Power / 418 Back Wheelshanks J.t. ( Come Play)
I don't buy that 15% number for ZO6s, especially. Factory rates the '01@ 385, and the 02+@405. Most bone stock Zs get 335 RWHP and 355, respectively. In both instances, 50 HP difference. Not surprising, considering they're the same chassis. Would a Z modded to 650+ RWHP then magically lose 100 HP, or double the HP loss, if using the straight percentage of 15? I'm sure at some point in the HP curve the percentage is hit, but I doubt a modded car would lose twice the HP from the same driveline. Nothing scientific, but seems obvious to me. My car is at about 480 RW now. That would translate to 570 HP, which I seriously doubt.
Why would you think the 15% changes if you are not doing anything to the drivetrain? The drivetrain doesn't magically become more effecient just because the engine is putting out more HP. The loss is going to remain constant unless there is a change made to the drivetrain so if you lost 15% at 400 hp you are going to lose 15% at 600 hp.
BTW the Z06 drivetrain may lose more rwhp because of the MN12 transmission creating steeper gears. I car with 4.10s will show almost 10 rwhp less than a car with 3.42s.
EXactly. Well put. If your chassis absorbs 50 HP while stock, what would make it absorb almost 100 HP with NO changes to the drivetrain, with a higher HP engine?
The main thing to keep in mind is that it is a very general guesstimation with out having to put the thing on an engine dyno. 15% is used in general around here because most of these cars are in the 320-500 window.
Louis
I am not an engineer but I speculate that some component of the drivetrain loss is absolute and some component of it is relative.Note that Lingenfelter shows their 600bhp TT package as having 530rwhp.
http://www.lingenfelter.com/Lingenfe...rboPackage.htm
Clearly the difference between 600 and 530 is not 50hp, but it's also not 15% (it's closer to 12%).
Now then, if you guys REALLY want to know the answer, everyone send me $10 bucks and I'll try and find an engine dyno shop that can run my twin turbo LS6 setup that last pulled 650 at the wheels. I can guarantee you the engine dyno will not read a mere 700 bhp, but it probably wouldn't hit 764 bhp either which is what 650 at the wheels would translate to assuming 15%.
Anyway, not sure why I went off on that tirade when Lou already said that the 15% number was a guesstimate for cars in the 320-500 window and the question was whether or not this car could produce 500.
My only point was, maybe he did, maybe he didn't, but he's not THAT far off from it if he didn't.
