C5 with isssues
Old Jan 13, 2007 | 08:20 PM
Dougzilla's Avatar
Dougzilla
Default C5 with isssues
I recently purchased a 2004 C5 12 days ago and I am having issues already. The service traction control, service active handling and low fuel are on after about 8 miles of driving and at 180* engine temp. Well today, I was trying to move it back in the garage and the car will turnover but wont stay running. The only thing I did was move both the seats.The battery was checked and it check out good. Just the charge was a little low. My question is? Could all these problems be from a bad battery. Or is there something under one the seats thats ties the modules together. By the way this car has 7800 miles to date and is going to the dealer on Monday for waranty work for the TCS problem if I can get it started.
Old Jan 13, 2007 | 08:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Humm, I have never heard of a low fuel light with a low battery. But the low battery causes all kinds of issues.
Good luck and enjoy the new toy.
Old Jan 13, 2007 | 08:47 PM
99 vett babycar's Avatar
99 vett babycar
because of all the different computers in this car a low or dying battery can cause just about ANY problem.
Old Jan 13, 2007 | 10:17 PM
jbauch357's Avatar
jbauch357
check and see if any codes were kicked, if so post them up...
Old Jan 14, 2007 | 08:56 AM
kg54trains's Avatar
kg54trains
Default Battery Issues.....
The car's need for electrical power is well documented. The odder the issues especially when there are multiple issues start with the battery. The battery is not always the answer but it has been at issue.
Old Jan 14, 2007 | 09:31 AM
Dougzilla's Avatar
Dougzilla
Thanks for the replies.
This morning I went to pull the codes and got the following codes:
PCM 1626h
TCS U1016h, U1000h
RTD U100h
BCM U1255h, U1016h
SDM U1000h, U1016h
LDCM U1016h
RDCM U1016h
SCM U1016h
RFA U1000h, U1016h
After checking the codes I tried starting it and TATDA! It started right up. Does this sound more like a bad ground contact or a battery problem? I know from working on helicopters all my adult life that a bad ground contact can cause all kinds of problems. Thanks for the help.
Old Jan 14, 2007 | 09:40 AM
Britishvette's Avatar
Britishvette
how do you view the codes?
Old Jan 14, 2007 | 09:55 AM
Dougzilla's Avatar
Dougzilla
Place the key in the on position, without engine running. Hold the options button and press the fuel button four times. The codes will then come up in auto mode then manual mode.
Old Jan 14, 2007 | 01:23 PM
rjbigdog's Avatar
rjbigdog
FYI: It works with the car running as well.
Old Jan 14, 2007 | 02:13 PM
Vettedreamer2's Avatar
Vettedreamer2
the "h" in all those codes means history, there would be a "c" if they were current issues in the system. I would try a diff. battery and see if they go away. Also you could be right about the grounds but with the milage being so low I would lean towards the battery being the problem.
Good luck.
Old Jan 14, 2007 | 02:18 PM
TEXHAWK0's Avatar
TEXHAWK0
Now that you have recorded all the codes, and they all are in history, why don't you clear them and see if they come back?
Old Jan 14, 2007 | 02:45 PM
jrose7004's Avatar
jrose7004
None of your codes are current. Clear them and pull them again!
Old Jan 14, 2007 | 03:37 PM
jbauch357's Avatar
jbauch357
PCM 1626h
TCS U1016h, U1000h
RTD U100h
BCM U1255h, U1016h
SDM U1000h, U1016h
LDCM U1016h
RDCM U1016h
SCM U1016h
RFA U1000h, U1016h
I am betting that the PCM1626 "Theft Deterrent System Fuel Enable Circuit" is the culprit for it not starting.
Get a good charge on the battery (or a new one - make sure it's a spill-proof gel type battery), clear the codes, and clean up all the grounds that you can find. Also take out the battery and tray then look underneath, see if there is a good deal of corrosion of any indication that the battery may have leaked (very common on these cars).
Old Jan 14, 2007 | 05:06 PM
Dougzilla's Avatar
Dougzilla
Thanks for the info again. I cleared the codes once before and they came right back the next day. I also cleaned the two ground clusters under the hood. All the codes seem to getting fewer, the PCM 1626 code pops up everytime.
Old Jan 14, 2007 | 09:36 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Just had the same with my twin brothers 2002 Z06.
We had pulled out the stock seats and tried to check the fit of a set of Corbeau's. I know on the 2001 you can pull seat connection and the car runs fine.
Check your connections under the drivers seat. Since you said you moved seats and had problem.
Old Jan 15, 2007 | 12:07 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by Vettedreamer2
I would lean towards the battery being the problem. Good luck.
Replace the battery and make sure that the old battery was not leaking.
Old Jan 15, 2007 | 01:21 PM
Dougzilla's Avatar
Dougzilla
The car is now at the dealer being fixed under waranty. I will let you know what they say is the cause
To C5 with isssues
Old Jan 15, 2007 | 04:35 PM
Factory 5's Avatar
Factory 5
If you replace the battery, it would be a good choice to pay a few $$$ more for an Optima. Well worth the dough.
Old Jan 15, 2007 | 07:15 PM
oldschoolvette's Avatar
oldschoolvette
I hate electrical problems, hope the dealer gets it fixed. Please post the final outcome. get a red top
Old Jan 15, 2007 | 09:10 PM
Bill 70Coupe's Avatar
Bill 70Coupe
I tend to agree with the battery theory, when the battery gets low they can act crazy. If the vehicle is still under GM warranty and an 04 should be the warranty will cover the battery. Don't let them try to make you purchase one. The 3/36 warranty covers the battery also.
Bill
