oxygen sensor code
Old Jan 14, 2007 | 11:14 AM
dwarmenzerk's Avatar
dwarmenzerk
Default oxygen sensor code
im getting this code..
P0157 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2-B
is this a bad oxygen sensor?
I have o2 sims for the rear... thanks guys!
could it also be that im currently running open manifolds, due to the fact im waiting on someone to make me a new mid pipe?
Old Jan 14, 2007 | 11:52 AM
Mike Mercury's Avatar
Mike Mercury
Sensor 2-B = behind the cat. - passenger side
Old Jan 14, 2007 | 05:12 PM
TUF-NUF's Avatar
TUF-NUF
From: kent ct - "if i'm not in the vette, i damn well better be on the yacht."
St. Jude Donor '13
if you're running open manifolds i'd ignore any codes until your system is in and complete...
Old Jan 14, 2007 | 05:39 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
If you have either open circuits (sensors not plugged in) or sensors that aren't in the exhaust stream, I'm with bikesmith.
To oxygen sensor code
