Anyone know of a good wire to hook up the gauge light to? So that the gaige light turns on only when the dash light turn on? i have had no luck searching. Thanks.
Under the panel where the active handling button is there is a brown wire that goes to the button...that wire lights up when the headlights come on. Hope this helps
Thanks guys. Now I can't figure out where to run the sender wires thru the firewall. I can't find any existiong other than the hood cables. Where have you guys ran your wires?
[QUOTE=Yellow03Z06;1558541613]Thanks guys. Now I can't figure out where to run the sender wires thru the firewall. I can't find any existing other than the hood cables. Where have you guys ran your wires?
Go thru behind the passenger (floor) fuse compartment into the battery well...that's where we ran mine.
I ran wires thru the hood cable grommet, worked okay.
