Throttle Body Upgrade Questions
) thoe you will get a better throttle responce?????????????
By the way, stock size is 75 mm at the throat. Aftermarket billet 78mm and 80 mm TBs will fit the stock LS1/LS6 intake manifolds. Any bigger and you need an aftermarket intake manifold.
If you feel you need to get better TB flow go with porting your existing stocker. Like said above, Shaner does a good job, you can also do it yourself, not that difficult.
Jusy my .02.
Jusy my .02.
For what it's worth, bored to death last winter, I replaced my ported stock TB with a Callaway 78 mm billet TB, along with a MTI Racing composit MAFS and Callaway Honker CAI (replaced vette doctors pro-flo + CAI). Gained basically nothing on the dyno from the old set-up although throttle response does seem much sharper.
Given the $650 price tag for the Callaway, porting the stocker seems like the smart way to go.
Now if you're like many of us here you're prbly looking at H/C packages and ----------
Anyway, good luck with the TB.
i was saying that the car had the headers and intake: I wish i had that power from those two items...
heres all thats done to the car: that made me the power
CAM 2000 LS1 / Y-car .500/.500 ** duration 198-209 ** LSA 115.5
3:42 Gear
180 Hyper tech Thermostat
2800 Vigilante Stall Converter
LS6 Intake
GM Performance spark plug wires
Iridium plugs
28.8lbs Fuel Injectors
Haltech Stinger Air Intake
Slp’s 1.85 Rockers, Titanium Retainers, & Keepers
LS6 Comp Cams Springs (26918-16) and Chrome Molly Hardened Pushrods
TPIS LT Headers,
GHL Exhaust
Magna flow X-pipe
B&M Trans Cooler
¼” coated aluminum tunnel plate
Aluminum end links
ZO6 Red calipers
ZO6 air ducts
Balis spring (in brake control valve)
GM drilled and slotted rotors Zink washed
Ceramic brake pads
LS1 Edit program and dyno tuning Done by dan at FLP
no
